<font color="maroon"><b>An update
I stripped the discs off the other day this photo you can see the wheel spacers
[/url]
I have now got the hub stripped down and off the car
released the 4 hex bolts attaching the disk to the hub conversion
removed the old disk
cleaned the hub spacer to get good contact with the new disc
and this one the you can see the components to be removed (ford Capri 2.8 i discs and calipers)
[/url]
This is the hub off the car you can see the 4 hex bolts and the aluminum conversion spacer
[/url]
Now the bad bits
The new disks did not fit the centre hole was about 1 to 2mm to small to fit ...
at the moment they are at my mates work getting the hole enlarged to make it fit
will put up a photo of the completed disc when finished </b> </font id="maroon">
