set of EBC Discs
Postby stevie_a » 31 Oct 2009 11:55
<font color="maroon"><b>Roy
I just came accross this on e-bay
Just thought I should show you (Click photo to e-bay link</b>)</font id="maroon">
[url="http://cgi.ebay.co.uk/Turbo-Groove-Brake-Discs-Front-ROVER-Triumph-TR7-75-81_W0QQitemZ200350933530QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item2ea5d8a21a"]Image[/url]
Postby bmcecosse » 31 Oct 2009 13:54
Thanks Stevie - bit too drastic! It's not that my brakes heat up/fade - in fact they work slightly better when pre-warmed - it's just lack of initial 'bite'. But as you know - they use the same pads as the Mini - and the Austin 1100 - so it's not surprising they are a bit feeble!
Image Image ImageImage
Postby stevie_a » 31 Oct 2009 19:56
<font color="maroon"><b>An update
I stripped the discs off the other day this photo you can see the wheel spacers
Image[/url]
I have now got the hub stripped down and off the car
released the 4 hex bolts attaching the disk to the hub conversion
removed the old disk
cleaned the hub spacer to get good contact with the new disc
and this one the you can see the components to be removed (ford Capri 2.8 i discs and calipers)
Image[/url]
This is the hub off the car you can see the 4 hex bolts and the aluminum conversion spacer
Image[/url]
Now the bad bits
The new disks did not fit the centre hole was about 1 to 2mm to small to fit ... :evil:
at the moment they are at my mates work getting the hole enlarged to make it fit
will put up a photo of the completed disc when finished </b> </font id="maroon">
Postby stevie_a » 01 Nov 2009 19:05
<font color="maroon"><b>I have just had a phone call to tell me that the discs that are on my car
were put in a lathe and 2mm taken out the centre hole
So all is good and correct and good to know
Thanks Mr G</b></font id="maroon">
Postby Shauniedawn » 01 Nov 2009 20:58
Hiya.
Out of interest what is the diameter that you have had to open the disc out to?
Cheers,
Shaun.
Postby stevie_a » 01 Nov 2009 21:16
<font color="maroon"><b>I will tell you tomorrow when I get the discs back from my mate</b></font id="maroon">
Postby Beans » 01 Nov 2009 21:24
I think that depends very much on the outer diameter of the conversion spacers rim.
I have steel spacers (from S&S) with a rim that is much thinner than Stevie's.
So no need to machine the discs.
Postby stevie_a » 01 Nov 2009 21:33
<font color="maroon"><b>It is the diameter of this part that is getting altered on the disc
the hole on the disc is just to small by about 1 or 2mm </b> </font id="maroon">
moestr7v8
Postby moestr7v8 » 01 Nov 2009 23:43
Hi Stevie
I had to have my discs bored out 2mm to fit as well, sorry I should have mentioned it on my earlier posting[;)] at least you would have been pre warned.
Cheer
Moe
Postby Beans » 02 Nov 2009 16:59
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by stevie_a</i>
It is the diameter of this part ...<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
That's the one I meant [;)]
Postby stevie_a » 05 Nov 2009 19:34
<font color="maroon"><b>OK got discs back
the centre hole is now a nice fit (now 72mm)
Question the centre bolt should be 5 lb f ft
but my torque wrench only goes down to 22.1 lb f ft
what is the best way to tighten up the nut so I know all is good</b> </font id="maroon">
Postby Beans » 05 Nov 2009 19:47
Never use a torque wrench for the front bearings.
Always tighten the nuts up, while rotating the hub/disc
When you feel that rotating the assembly needs more force you are there.
It’s all a matter of feeling [;)]
Postby stevie_a » 05 Nov 2009 19:51
<font color="maroon"><b>Thanks Beans
Will give that a go
According to Haynes you tighten it up to 5 lb fft
then turn it back one flat of the nut. </b> </font id="maroon">
Postby stevie_a » 06 Nov 2009 20:34
<font color="maroon"><b>I finished one side of the brakes tonight
Before i had to do child minding duties
Hopefully i will finish off tomorrow </b> </font id="maroon">
Reddragon
Postby Reddragon » 07 Nov 2009 12:47
Just to clarify on what you have done here. You purchased the EBC rotors, part # GD200, for the stock TR7 setup.
Where did you get the spacer to make up the difference between the stock rotor and the EBC rotor? If you made these can you provide the demensions?
Since you already had the Capri calipers installed, did you have to make any adjustment to them for the increased size of the vented rotors?
Looks good so far, please keep us updated on the how they work once finished.
Dale
1974 TR6
1977 TR7 FHC
Users browsing this forum: No registered users and 51 guests
