Carb mounts
Spike
Carb mounts
Postby Spike » 15 Nov 2014 13:55
Had a productive day in the garage tinkering, coolant flush, fitted some new number plate lights, and cleaned up some earthing points and connectors.
I also changed the carb mounts, simple job but with big hands it's a bit fiddly. I know the quality of the replacement ones aren't that good, but I was surprised how ropey they were, even had to open up the holes to get them to fit.
I heard that you can get solid ones from the dolly owners club, has anybody fitted these?
Spike
Postby Spike » 15 Nov 2014 13:58
Also my cheap Draper spanners didn't help either, they're quite crudely cast. Next on the list some decent spanners.
Postby Chris Turner » 15 Nov 2014 14:28
The aftermarket carb mounts will be ok for a few months.
www.triumphtrs.co.uk
THE Coca Cola car
TR7 Sprint SJW 539S
Postby Workshop Help » 15 Nov 2014 14:43
A gracious good day to you, Mr Spike.
I now politely beseech you to stop everything you are doing and hustle down to your nearest hardware store to purchase two, 3" diameter hose clamps.
Next, peruse my article in The Workshop Manual entitled, 'Z-S Carburetor Mixture Screw O-Ring'. Observe in the top three photos how the hose clamps secure the carburetor cross plate to the intake manifold.
Your installing the clamps will prevent the new and cheesy rubber mounts from falling apart, which will be MORE than a little irritating.
rosey
Postby rosey » 15 Nov 2014 17:01
I have just bought some solid carb mounts from the guy in the USA that makes them, I can post the details if you are interested but they cost me $155 including shipping.
They are very well made and are in my opinion a better option than the poor replicas currently available from suppliers, which aren't servicable parts.
1981 Purple Grinnal 2.0L
1977 TR7 4spd FHC Tahiti Blue
Postby john 215 » 15 Nov 2014 18:25
I help support the weight of the carbs etc. with a couple of hose clips.
Postby dursleyman » 15 Nov 2014 21:10
If you want some solid mounts have a look at the Dolomite Forum here in the UK, they recommend and sell them as well. £67.99 a pair.
1981 TR7 Sprint DHC
MikeRotherham
Postby MikeRotherham » 16 Nov 2014 10:41
I used this to make a couple of clips for mine.
http://www.amazon.co.uk/Draper-55592-Ho ... +hose+clip
There's a post by Mildred that elaborates how they fit.
Mike
rosey
Postby rosey » 16 Nov 2014 15:06
1981 TR7 Sprint DHC
I read that you had to join their club to buy them, so I ordered them direct from the USA.
rgsSpider
Postby rgsSpider » 17 Nov 2014 15:18
I've had the aluminum mounts on my Spider for over a year now and not had any problems with them. A great upgrade in my opinion!
Got them here: http://home.comcast.net/~rhodes/TR7_adapters.html
Randy
Image Image Image http://rgstr7spider.tumblr.com/
Postby jclay (RIP 2018) » 17 Nov 2014 23:11
I have the same aluminum mounts that rgsSpider has on his car that I bought from Anthony Rhodes at spamiam@comcast.net. Mine are holding up a set of Weber Carbs that are much heaver than the stock carbs.
Postby Chris Turner » 18 Nov 2014 06:08
I discussed the US made mounts with Dave Rose at the NEC, he says they are very well made, I will be ordering a pair shortly.
THE Coca Cola car
TR7 Sprint SJW 539S
Spike
Postby Spike » 18 Nov 2014 06:13
Something else to add to the list, they do look good though.
Need to fit the disk and calipers from Russ, refurbish the suspension and sort out the wipers first.
regards
Postby Workshop Help » 18 Nov 2014 11:35
We're confused. Are you adding the carb mounts or the two hose clamps to the list? The hose clamps are a LOT cheaper and far EASIER to install while accomplishing the same result.
Postby FI Spyder » 18 Nov 2014 13:02
Yah, but they don't look as good. A good temp solution until something better comes along. I'm keeping a eye out for something cheap and eye appealing the is repurposed for Yellow TCT. Something in the way of a turnbuckle or solid clamp.
