Could be worn or perished bushes on the rear axle linkages causing movement. Our cars also rot in the nicely designed rust traps where the floorpan is welded to the rear passenger bulkhead, especially around the radius arm mounts. This allows the radius arms and rear axle to move about under acceleration and braking.
If you're lucky[;)] it might be a worn gearbox rubber mounting allowing the 'box to move around.
Shit happens when you have an older car.
