Strange sound? Chassis???
Adam Parr
Postby Adam Parr » 22 May 2010 02:59
Hey guys.
Every time I give the throttle a stab, or shit down a gear, when the car jerks, i can hear a sound like something is knocking against the top of the left rear qrt panel / B pillar.
an ideas?
regard Adam
Postby PeterTR7V8 » 22 May 2010 04:15
Recommend you don't shit your gears! (couldn't resist)
Jack the car up & take the left rear wheel off. Inspect the shock mounts & have a look at where the upper & lower trailing arms are attached to the chassis. It is rare for the trailing arms to pull the mounts off the shell but it can happen. Take the trailing arms off & have a look at the bushes. If you have the rubber bushes they will probably be as old as the car & will be shagged.
Good luck.
Postby Hasbeen » 22 May 2010 06:18
What part of Brisbane are you in Adam?
If you can't find it, & your not too far away, you could bring it
down, & I 'll have a look/listen, if you like.
Postby busheytrader » 22 May 2010 07:26
Could be worn or perished bushes on the rear axle linkages causing movement. Our cars also rot in the nicely designed rust traps where the floorpan is welded to the rear passenger bulkhead, especially around the radius arm mounts. This allows the radius arms and rear axle to move about under acceleration and braking.
If you're lucky[;)] it might be a worn gearbox rubber mounting allowing the 'box to move around.
Shit happens when you have an older car.
Bobbieslandy
Postby Bobbieslandy » 22 May 2010 15:11
never use the words "shit" and "stab" in the same sentence. Sounds like a good case for poly bushing. are the exhaust mountings ok?
HDRider
Postby HDRider » 22 May 2010 16:02
Also check to see that the muffler is not hitting against the frame above it.
Edward Hamer
Petaluma CA
nick
Postby nick » 22 May 2010 23:00
I had this exact problem shortly after I removed the gas tank and reinstalled. Turns out I did not have the proper torque on the trailing arm to body attachment. Torqued it to spec and all is fine.
nick
'79 TR7
Adam Parr
Postby Adam Parr » 23 May 2010 21:51
Hey guys,
strange thing,
is quickly as the sound has come, it had gone to.
Ill probably have a look at the suspension today.
Hey Hasbeen, where abouts in Brisbane are you?
I'm out at wellington point.
At everyone else, i couldn't understand why everyone was saying "don't shit your gear".... ahhh i see now, proofread before posting :)
Postby Hasbeen » 23 May 2010 22:31
I'm at Tamborine, south of Beenleigh Adam.
Users browsing this forum: Google [Bot] and 99 guests
