Can anybody give me any good tips before I begin because I don't want to make a right hash of it now, this far down the line. I have put NO oils/lubes in yet, so reckon I'll do one system at a time. This is my proposed plan, and I'd appreciate any tips or "gotcha"s to give me the best chance of success.
1) Fill and bleed brakes and clutch with Dot 4 fluid.
2) Fill the coolant system and hope that doesn't leak. I plan to leave that water in for a while before flushing out the system and adding a suitable anti-freeze. Is normal tap-water going to be okay for a while, or do I need to consider any alternatives or additives?
3) Fill the engine with a cheap 20W50 oil. I'll use that to get the engine going and for the first 50 miles or so, then drain it, change the old filter for a new one and add Castrol 20W50 with a splash of STP.
5) Gearbox and differential oil, again, el cheapo(ish) stuff to get the car going then drain and refill with top quality stuff.
4) A gallon of unleaded to check the integrity of the fuel system and give me a fighting chance of getting the engine running! Once I get confidence I'll increase the amount by a gallon at a time.
Now for the big question - what are the best brand and model of spark-plugs that I'll need to buy? I have put a new condensor and set of contacts in, but will have a go with the original spark-plug leads to start with.
That's my plan - are there any glaring flaws or omissions that could save me from making a monumental mistake? I'd also appreciate that if you think this plan appears okay could you give me some feedback so I can gain some confidence [:)].
Thanks very much for any help - wish me luck!!
Mac
</font id="blue"></font id="size2"></font id="Comic Sans MS">
