Body Removal
earlosborne55
Body Removal
Postby earlosborne55 » 24 Sep 2009 10:59
Has anyone in this forum removed body,fenders etc from a TR7?. I've looked for bolts but it appears that the body is welded instead of bolted. (or is could be bad eyesight). If anyone has done this process could you email me or answer this post. Cheers
Red
Postby Red » 24 Sep 2009 11:38
Yep, I'm afraid it's all (spot) welded on.
What parts are you looking to remove?
If you download TR7_man.pdf from Jclays' site:
http://homepage.mac.com/jclaythompson/. ... TR7man.pdf
There's a section there which will tell you exactly where all the spot welds are.
Garry
1976 2.0 (soon to be 3.5!)FHC
http://reds-tr7.blogspot.com/
earlosborne55
Postby earlosborne55 » 24 Sep 2009 11:55
Thanks for the link. I hope this doesn't turn into a fiasco ...Appreciate
Postby Hasbeen » 24 Sep 2009 13:04
The 7 does not have a separate chassis, like earlier TRs, you can't
remove the body as such.
earlosborne55
Postby earlosborne55 » 24 Sep 2009 13:07
Thanks Hasbeen....I'll save myself the trouble and scrap the thought. Cheers
Postby jclay (RIP 2018) » 24 Sep 2009 13:09
Also, download "TR7_Welding.pdf" as it has the locations of all the spot welds.
