FHC RESTO
Postby John Clancy » 01 Jun 2009 08:37
I think it's a shame to put a V8 in such a good looking Speke car. But at least it's survived this long and will continue for a good while yet. So well done!
Postby busheytrader » 01 Jun 2009 08:52
Interesting shots of the heater with dash removed.
I've rebuilt a replacement heater box from 2 others with new rubber pipe seals, stainless pipes and foam. Propshaft, remote gearbox housing bushes and rear axle pinion seal renewal all prevented me from swapping it with the duff heater in the last few weeks. Now the good weather's here I might not change it for a couple of months!
frankman
Postby frankman » 01 Jun 2009 21:00
Please Keep the Color !
.. a Dolli Engine would have been not bad to.
Hello from Switzerland
Frank
Chubster
Postby Chubster » 01 Jun 2009 21:42
Good luck buddy, once apart they seem to take a lot longer to put back. This one took 12 years and was registered in December 1977.[8D][8]
Postby RUDDY » 04 Jun 2009 15:39
Strip down continues ........
cheers, Paul
nofinchance
Postby nofinchance » 04 Jun 2009 17:46
hope you don't mind as this is off topic and a bit cheeky[:p].I was wondering what plans you have for the interior from the red car? My interior is a mix and match mess.i have a red car and was gonna go mad for a rimmers retrim however all my funds have gone on rip off garages[xx(].on topic ,you have been busy this week keep up the good work and the pace.heres hoping you don't loose any vital bits(of the car,or you with power tools[;)])
Postby RUDDY » 04 Jun 2009 18:58
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by nofinchance</i>
hope you don't mind as this is off topic and a bit cheeky[:p].I was wondering what plans you have for the interior from the red car? <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
Apart from the bits required for the V8 conversion and a few odds and ends that are worth keeping for spares the red car will be parted out and its remains will then be up for grabs. I guess that means the seats are available, the seats are red/black check but the door cards are all black.
cheers, Paul
nofinchance
Postby nofinchance » 06 Jun 2009 07:16
I had my fingers crossed for tan but red check is a better match than my green[B)].I may also need the carpet as mine seems to be a puzzle of cut offs from carpet world[:D].Also I have two left door pulls so one of mine is upsidedown.I may need other odd bits of trim so let me know what and when is available with prices please.Also you general location would help as If you are in the outer hebrides or something then it's a bit too far for me[:p].Good luck with your resto' I have had many problems with so called specialists so wish I could DIY[:(].You are making lightning progress I have waited 8 weeks for a Triumph specialist to fit a fuel tank[:0]
Postby RUDDY » 20 Jun 2009 18:20
Shell is now virtually bare, few cables left to remove and wiring, got the shell mounted on the turnover frame and rolled it over gently for access to underside. One stubborn bolt stopping rear arm coming out,it will receive the grinder treatment tomorrow. Will start cleaning underside to remove old underseal prior to media blasting, crucial areas appear to be pretty solid [:D].
cheers, Paul
Steve-LPS-Thomas
Postby Steve-LPS-Thomas » 20 Jun 2009 19:40
I thought for one horrible moment that the red car was my first TR7 bought in 1979 I think. It's reg was WTA629S I think. Both TA and TT being Devon plates. I also had a DHC with 543 in the number, hence the heart stopping moment. I would have expected WTA629S to have departed this world a long time ago.
At around that time there were lots of Java green TR7's about and I thought that it was the most disgusting colour. Now I absolutely love it and look forward to the day I own a TR in this colour. Please don't change it! I used to hate FHC's too but now I prefer them to DHC's. I used to hate the build quality of Speke cars but now....
<ul><b><li>Ex BL Development TR8 (Rally Replica).</li>
<li>The First and Only UK TR7 "Victory Edition" (Now Sold) </li>
<li>Ex-BL/Safety Devices Development 8v Rally Car.</li>
<li>"The Shape of things to Come" Trailer.</b></li></ul> Image
Postby PeterTR7V8 » 20 Jun 2009 22:40
I need one of those rotisseries to use with the car fully assembled! No more long hours on my back on the cold concrete floor.
Good luck with the resto.
Postby RUDDY » 10 Jul 2009 17:28
Postby UKPhilTR7 » 10 Jul 2009 21:57
Do you want to sell the stand that you have your car on when you have finished with it?
Postby Beans » 10 Jul 2009 23:54
Paul,
For an early TR7 it looks pretty solid, but make sure you treat all suspect areas properly, especially the rear of the floor section, rear axle pick up points, boot floor/spare wheel well and the rear chassis legs.
Just found a few (very tiny) rust holes on my DHC in these areas, which looked much more solid than yours before shot blasting.
Gr.T.
Postby Beans » 10 Jul 2009 23:55
Paul,
Gr.T.
Users browsing this forum: No registered users and 113 guests
