How to remove door rain gutter from FHC
Mowog73
Postby Mowog73 » 01 Sep 2008 11:37
So how does the black metal rain gutter at the top of the door opening come off?
My son and I are sanding down the body and this is one of the last pieces to remove in order to sand and paint in behind the rain gutter.
Reddragon
Postby Reddragon » 01 Sep 2008 12:20
<b>Mowog73</b>
If you have a pair of channel pliers, put some duck tape on the teeth area. Then start at the rear most end. Gentlely pry from the bottom upwards towards the roof. This should pop the bottom flange off the rail. Once that is off you can take a small screwdriver and work it under the rail toward the front of the door.
Be careful in doing this as these have a tendence to kink if to much force is used.
Dale
1974 TR6
1977 TR7 FHC
Mowog73
Postby Mowog73 » 02 Sep 2008 11:21
Hi Dale,
Do you mean to have the jaws of the channel lock around the top and the bottom of the gutter and then pry upwards?
76 TR7
Reddragon
Postby Reddragon » 02 Sep 2008 22:01
Yes, that is what I mean. Use the teeth as the lever with out a crushing effect on the channel. It takes a very light touch when doing this. It will then pop off.
Once you have the channel off you will be able to see that the bottom of the channel has an inverted "V" on it to hold this piece in place.
When you go to put them back on, just need light tap on the V grove to give it its locking power.
Dale
1974 TR6
1977 TR7 FHC
Mowog73
Postby Mowog73 » 12 Sep 2008 15:52
Thanks Dale for the rain gutter removal tip. Using the channel locks and a bit of tape and a screw driver, the gutter came right off.
1973 MGBGT
1976 TR7
1980 Spitfire 1500
V8Wedgehead
Postby V8Wedgehead » 18 Sep 2008 01:20
Mowog-
I would try to put as little paint on the lip that the moulding/trim goes onto. If you over paint it you will never get the trim back on or at least with out bending it![:(]
Michael
1980 TR8 FHC/Works Rally Project
"If it is broken then fix it....if it is not then make it faster!"
Mowog73
Postby Mowog73 » 18 Sep 2008 11:29
Good point Micheal. Right now the gutter has been stripped of all paint. Tomorrow I'll be spraying on the primer and will keep the amount put on the gutter light (as well as the paint to come).
1973 MGBGT
1976 TR7
1980 Spitfire 1500
