LSD Advice
Stevie P
LSD Advice
Postby Stevie P » 17 Jun 2015 09:15
Hi guys
I have acquired a back axle with a new LSD in it, plate type, do you think it will be noisy in the FHC, should I sell it to a rally boy and get a Quaiffe ATB?
Thoughts?
prackers
Re: LSD Advice
Postby prackers » 17 Jun 2015 11:05
In my (limited) experience noise shouldn't be a problem, I have a plate type in my Westfield and have never noticed any sounds from the diff, although the car is fairly loud what with wind plus mechanical noise. On the other hand I had a Twin-cam Escort Rally car many years ago with a plate diff and that did growl and chatter under hard cornering, but that was in the late 70's and I assume the technology has moved on since then?
I have a Quaife ATB in my current TR7 project but currently do not have more than a few miles on it so not really in a position to comment on it just yet.
In your shoes I would probably just try it in the car, the pro's and con's between the two are well documented elsewhere and in a TR the mileage is unlikely to cause the plate type to wear out in your lifetime!
1978 TR7 FHC 4.0 Toyota V8
1979 TR7 DHC 5.7 Chevy V8
1980 TR7 FHC 2.0
1981 TR7 DHC (not decided yet)
Re: LSD Advice
Postby dursleyman » 17 Jun 2015 15:30
I have run plate type LSD's in several rally cars and they can be quite noisy when they get hot. Reversing into a parking space in service was often accompanied by loud "cracking" noises. This was after some hard use on special stages. Never heard a thing when they were cold.
(The noise thing was a bit embarrassing in my Group N Corolla GT Coupe because the standard LSD in those cars which we should have been using was a different type and didn't make noises, but it was too "loose" for competition. Luckily no one who knew any better heard it or bothered to complain)
