Front bumper mounts - help !
tr7dan
Postby tr7dan » 10 Feb 2015 19:29
1981 TR7 dhc
Can anyone help?
I took the front bumper off a long time ago and seem to have misplaced the fasteners that hold it on the car.
The flexible mounting blocks that are fixed to the back of the bumper have three 8mm short threaded studs on each side that locate in the mountings on the car but the oblong holes in the mountings are much bigger than a standard 8mm nut and washer - can anyone tell me how the bumpers mount to the car ?
Should I have some large diameter washers to go at the back of the mountings and if so what size are they ?
I have a box with a lot of fasteners and brackets and bits that I took off the car and had zinc plated so they are probably in there - it's just identifying them
cheers
Dan
Postby REPLIC8 » 10 Feb 2015 19:46
Hi Dan,
Somewhere in your box of fittings you should find 6 large washers about 25mm dia with a flat edge, about 2mm thick. Use these plus a spring washer and nut. The elongated holes in the body are there to allow some side to side movement of the bumper so you can line it up nicely. If you can't find the original washers just use some thick penny washers. [:)]
1981 TR7 FHC
tr7dan
Postby tr7dan » 10 Feb 2015 20:07
Thanks Andy
when you say with a flat edge do you mean 'D' shaped ?
Postby REPLIC8 » 11 Feb 2015 07:45
Yes, 'D' shaped would be a better description. [:)]
1981 TR7 FHC
