My led back light conversion wort's and all
Postby stevie_a » 18 Jul 2009 16:51
(Part 1)
At Billing i showed off some of my handy work to a selected few
but as it is still work in progress I didn't put it up here
I am now not far from complete
I will show you what i have been up to
well it all started off I wanted a very subtle look to the back
I removed the orange cover from the indicators
put in a direct replacement bulbs but it was not a good success too dull
so i started to look at other ways to do it
After many months I found a place that could supply me with full led boards
Amber , Red , white
I got a spare set of back lights and set about them
Put them in a mill and cut them down
This will let the light go strait out
I set about putting a back onto them using
and
At this stage I hold up my hands and say to the people who use this stuff
I salute you as it is a nightmare to use
As you see from my first attempt
After i finished it back on the mill
and infill with resin
Pop in some holes
and cut to fit cards
Put on some thin foam back
Insert the boards
I then put some aluminum paper to give some kind of reflective properties
some rough wiring
Postby windy one » 18 Jul 2009 17:08
Very nice work! [:p] I am very interested on the outcome.
Postby bmcecosse » 18 Jul 2009 20:05
Great story Stevie! But I feel you should have incorporated the Fog Warning lights in there too! I've just done that - using double filament bulb holders - and the car is much nicer without the ghastly hanging down aftermarket lights at the rear. It passed MOT without comment. If they could do a section of RED lEDs with some WHITE ones inbetween - on separate circuits - then the original reversing light spaces could be both RED Fog Warning and WHITE Rev Light! Are you going to reveal the supplier of the LED boards ???
Postby stevie_a » 18 Jul 2009 21:17
As said PART 1 and the title says wort's and all ...[;)]
the red led's are twin voltage
Postby john 215 » 18 Jul 2009 21:22
Saw Stevie's LED conversion at Billing in the dark and is very very impressive,rear lights that a following driver can actually see and reverse lights that are brighter than standard headlamps!! Great saftey aspect!! As well as the red with clear below looks a lot cleaner as well IMHO not to mention interior lighting he has also done and of course LED very litle current draw [:)]
BMCECOSSE i know where those boards came from [:p] but if i told you then would have to kill you as Stevie would kill me but safe to say very clever source, OMG have i said to much already [xx(]
wedggie perrin
Postby wedggie perrin » 19 Jul 2009 20:31
Steve,
Nice mod. What flasher unit did you fit to make the indicators flash at correct speed?
Gareth
Postby Gareth » 19 Jul 2009 20:47
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Great story Stevie! But I feel you should have incorporated the Fog Warning lights in there too! I've just done that - using double filament bulb holders - and the car is much nicer without the ghastly hanging down aftermarket lights at the rear. It passed MOT without comment. If they could do a section of RED lEDs with some WHITE ones inbetween - on separate circuits - then the original reversing light spaces could be both RED Fog Warning and WHITE Rev Light! Are you going to reveal the supplier of the LED boards <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
Just remember it is illegal to have a fog light within 100mm of a brake light. You may have passed the MOT but????? (you are illegal)
Gareth
1980 TR7 DHC, 1980 TR7 Auto (Spares)Enough Parts to build another.
1980 Triumph Spitfire, 1964 Beach Buggy, 5(Five) 4x4's (Korean)
Wifes drive a Saab 93 Conv
http://www.ssangyongclub.co.uk
Postby stevie_a » 20 Jul 2009 09:37
As said the led boards are from a cleaver source
they are from one of these
the red boards are twin brightness but as i will explain later i was having problems
with the brightness match from each side
I have heard and been warned about the 100mm law
but I hope to resolve the problem, But i was looking at the after market
rear fog lights and discovered a surprising fact that they are positive earth
so you can't just put in a direct replacement led bulb
I will be showing more later with photos.
wedggie perrin
Postby wedggie perrin » 20 Jul 2009 11:09
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by wedggie perrin</i>
Steve,
Steve, cough, cough!
Postby stevie_a » 20 Jul 2009 11:27
sorry mate I will get you a model number
it is a flasher unit for led's
you can also put in a resister I had to do that for the hazards
I will also supply numbers for them
wedggie perrin
Postby wedggie perrin » 20 Jul 2009 17:58
Thanks Steve that will be a great help.[:)]
Her is a link to legal requirement of fog lamps-
http://www.opsi.gov.uk/si/si1989/Uksi_1 ... _en_16.htm
Postby stevie_a » 25 Jul 2009 21:15
Steve,
OK this is what I had in It was a Halfords electronic flasher unit all you do is ad an earth to make it work
I put in this when I fitted the led's to the back and front of the car
As you see NO earth (yes i know [:o)] it is now insulated
for the hazard lights i had to put in a resistor
I got that from maplin this was it put in one of the lives at the rear lights you can see it as a white block
wedggie perrin
Postby wedggie perrin » 26 Jul 2009 16:11
Thanks Steve,Great help.
Managed to take my rear lights off and remove the orange insert and respray the body in "chrome" silver, fit new gaskets and of course orange LED indicators. I already have the double stop/tail mod done with LED bulbs.
Postby bmcecosse » 26 Jul 2009 17:51
Yes - I know Construction and Use Regs require 100 mm - but that's not to say mine are now 'illegal'. Just means Triumph couldn't produce them like that - surely they must have made a mess of the rear light design at the time - to not have the fog lights incorporated! MOT man doesn't care about C&U regs - he just wants to see RED lights - and I will never have them switched on anyway - except to pass MOT each year!
I rather suspect the LED lights conversion may be 'illegal' too - since they are not EU approved! But - who's going to bother - it does look a great conversion - although straight swop LED 'bulbs' are readily available - and are EU approved.
Postby stevie_a » 26 Jul 2009 21:58
Originally posted by bmcecosse
Although straight swop LED 'bulbs' are readily available - and are EU approved.
The only problem with those are that led lights are only effective when viewed from strait on
And as we know the TR7's bulbs all go in from the side
That is what started me on this in the first place
Users browsing this forum: No registered users and 59 guests
