FHC RESTO
Postby RUDDY » 11 Jul 2009 06:59
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by UKPhilTR7</i>
Do you want to sell the stand that you have your car on when you have finished with it?
Sorry Phil, stand has a q' of people waiting for it, they are very easy to make, should cost no more than about £50 for materials if static, a bit more if on castors because good ones are expensive.
cheers, Paul
Postby RUDDY » 11 Jul 2009 07:04
Paul,
For an early TR7 it looks pretty solid, but make sure you treat all suspect areas properly, especially the rear of the floor section, rear axle pick up points, boot floor/spare wheel well and the rear chassis legs.
Just found a few (very tiny) rust holes on my DHC in these areas, which looked much more solid than yours before shot blasting.
Cheers Beans, think rust always looks worse on a picture, majority is very slight surface rust and a bit of pitting, rest assured that the media blasting will find the weak points and these will be repaired correctly. Got to slow down a wee bit on this car, I retired from work on ill health 2 years ago, been ok up to now, a few weeks steady work on the TR has taken its toll so I am stepping back for a while and having a few weeks away from it to recharge my batteries.
cheers, Paul
Red
Postby Red » 11 Jul 2009 13:54
That looks just like the bottom of my car at the moment! Well, except with more green and less rust... [;)]
Looks pretty solid though - goes to show that even our old Speke cars can survive the years if they're looked after properly!
What are you painting the underside with - is it getting a respray in body colour?
Hope you feel better enough to get back on to it soon.
Garry
1976 2.0 (soon to be 3.5!)FHC
http://reds-tr7.blogspot.com/
Postby RUDDY » 29 Jul 2009 18:38
Nice sunny day today when the blaster paid a visit, at least now I know which panels to order [:0]
Postby Beans » 29 Jul 2009 21:04
Does look much better then I expected.
Very good base to start with [:)]
Postby silverseven » 30 Jul 2009 02:38
probably better than most of our cars !!!
( heck,I sure even my dhc would have work to do after a blasting like this )
Ruddy , your project rocks, glad to see your doing it right [8D]
Jolyon39
Postby Jolyon39 » 30 Jul 2009 05:00
That is going to be a great car. You are starting in the right place, the body.
I found rust underneath in an out of sight place, out of sight even in your photo's.
Check the top of the rear chassis rails in the fuel tank enclosure. Stuff sits up there and eats down into the rails.
regards
Jolyon
stricky
Postby stricky » 30 Jul 2009 11:01
great condition! you picked the right car, looking great [:D]
'79 TR7 V8 FHC
Photo's Here - http://s480.photobucket.com/albums/rr170/stricky1967/
stricky
Postby stricky » 30 Jul 2009 11:05
Hey Paul, who's doin the spray painting for you? anyone local? I'm looking for someone to do my white car too.
cheers
jon
'79 TR7 V8 FHC
Postby RUDDY » 05 Aug 2009 17:51
Not a lot to report, now got car into unit where I can get started, ordered a few panels from S&S so hopefully they will arrive in next couple of days. Just trial fitting new door to get gaps even before I replace sill, car is supported on stands on chassis as well as turnover frame.
cheers, Paul
Hope I don't get parts mixed up jumping from one project to another, not to mention 2 other Escorts that are ongoing as well [:0]
Postby Beans » 05 Aug 2009 18:23
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by RUDDY</i>
... Hope I don't get parts mixed up jumping from one project to another, not to mention 2 other Escorts that are ongoing as well ... <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
Sounds vaguely familiar [:)]
... but I do have mixed up some parts, just trial fitting here but ...
V8Wedgehead
Postby V8Wedgehead » 06 Aug 2009 20:14
Looks familiar........but in the opposite direction![;)]
Michael
1980 TR8 FHC/Works Rally Project
Postby RUDDY » 09 Aug 2009 16:51
Look away now if you are squeemish [:)] , had a couple of hours today on the shell, decided it was time to remove some panels, firstly an exploratory cut in the front wing to see how bad it is and what runs where, knew there was a loom in there somewhere, was quite pleased with the panel behind, again the wee bit of surface rust at the top looks worse in photo, the sill has a couple of holes at the bottom and front but this is to be replaced anyway, inner arch has expected rot where it meets the wing, again I have a new inner tub ready to go in, nose panel where the 4 bolts are is perfect. Also remove lower rear sill, not impressed with the pattern repair panel, will need some work to get a very good fit, seems too long. Had to stop for a while as there was a show on locally and the last remaining Vulcan bomber was buzzing the unit, awesome sight and sound [:0]
cheers, Paul
mak
Postby mak » 09 Aug 2009 17:35
That looks such a good car to start with - I'm very envious! What are you planning for the front panel and rear deck seams? The one front seam is cracked on mine and just starting to show signs of rust - when it gets repaired I want to make sure it's done properly but not sure whether this should be seam welded, brazed or lead loaded..
Postby RUDDY » 09 Aug 2009 19:29
On the front seam I was just planning on treating both mating faces properly with anti rust paints , maybe a bit of topcoat as well , then a bead of seam sealer prior to fitting the wing, then pull the bolts up. Don't think there is supposed to be a weld or anything down this joint and the one I just too off wasn't, happy to be corrected.
Cheers, Paul
Users browsing this forum: No registered users and 95 guests
