My left turn signals work fine but when indicating right the rear lamp stays on, as does the green dash lamp. The front lamp does not come on though, i've checked / replaced the front bulb anyway. Is this a common fault? i'm planning on checking the wiring immediately behind the front lamp then removing the indicator stalk as i've got a feeling it could be a dirty contact in there but thought i'd ask you knowledgable guys an gals first before barking up the wrong tree!
Thanks again,
Rob.
