Cabin/cockpit ventilation
Marsu
Postby Marsu » 01 Jul 2010 17:53
I just noticed the following approach used on jdg941v illustrated below to provide cabin/cockpit ventilation.
It seems it would allow to more V8 induction options withoput losing the fresh air feed to the cab.
Has anyone else tried this?
V8Wedgehead
Postby V8Wedgehead » 01 Jul 2010 19:13
My TR8 project will eventually use the area at the back of the hood/bonnet to pull air into the carb. This is called "cowl induction". I will most likely do the same as JDG941V, hose for air to the heater core opening.
Michael
Postby FI Spyder » 02 Jul 2010 02:38
The phenomenum is caused by a high pressure area at the base of the windshield so the V-8 is actually sucking it way forward. Unfortunately there is a corresponding vacuum at the rear as the gas in the tank is being sucked forward also.[:D]
Postby jclay (RIP 2018) » 05 Jul 2010 22:27
Beans uses one that feeds from the front of the car.
Postby Beans » 06 Jul 2010 17:48
Had to do that as I couldn't use one of the two holes
(wiring loom and mastercylinders being in the way)
Will probably change it when I start on that car (enlarging the diamter to ø75mm
Postby jclay (RIP 2018) » 07 Jul 2010 03:23
Don't forget that reproduction floor vents are now available that fit in the foot wells.
Clay
Postby Beans » 07 Jul 2010 17:05
Interesting, where from?
Postby Underdog » 07 Jul 2010 20:51
Pretty sure TSI sells em. Ted lists them and other stuff on ebay sometimes.
Yep, on his site.
http://www.tsimportedautomotive.com/images/footwell[2].jpg
Well that doesn't work...lets try this
http://www.tsimportedautomotive.com/tr7_tr8.html
Jim Underwood
Users browsing this forum: No registered users and 107 guests
