So I thought I'd poke that crusty looking bit...
MrT
Postby MrT » 19 Apr 2010 19:49
You know, the inner wing...[}:)]
Now, I knew they'd been 'repaired' in the past, and whilst they were probably OK when done, it's not up to my expected standard of neatness. At a quick glance, the offside is the worst - there's plates on the inner wing in front of and behind the turret, badly blended in with filler, and I think the turret may be made of those seperated side and top plate kits[V].
But my main reason for digging deeper was the crusty/flakey wing mounting rail. Or rather, the area where itr should be! Oddly/luckily, the outer wings themselves <i>appear</i> to be pretty good though, so should at least be reusable, assuming I can get them off OK[:)]
So my quuestions are...
1. How is the front wing mounted? It looks like spot welds along the top (most of which as gone anyway!) and bolts to the A pillar, but what about the rest? I think it should be bolted to the nosecone, and spot welded to the sill and front panel - am I right?
2. What should the wing mounting rail look like? I can't find any particularly clear pics of this area with the wing removed; is it a box section, or a straight forward 'shelf', etc?
3. More importantly, got any pics of what this area <i>should</i> look like without an outer wing fitted?
Thanks in advance.
Dale
Agrati Capri (x2)
Triumph TR7
Yamaha SRX-6 (x2)
Skoda Octavia vRS 2.0T FSi
Henk
Postby Henk » 19 Apr 2010 20:32
I have on a 7 never replaced the wings, but I have somewhere found a picture without a wing.
[img][IMG]http://i189.photobucket.com/albums/z26/TRHENK/dr-inner-w-arch.jpg[/img][/img]
Henk
1980 TR7 US Convertible
1978 Mini Clubman Estate
willywonka
Postby willywonka » 20 Apr 2010 06:43
MrT.
JClays excellent web site will help you out.
If you scroll down the page to the 'Welding' section you will find all of the locations for the spot welds.
http://homepage.mac.com/WebObjects/File ... ring4.html
All the Gear, no idea
MrT
Postby MrT » 20 Apr 2010 19:51
Thanks for that - I never knew that site existed[8)]
That should come in very useful...
Dale
Agrati Capri (x2)
Triumph TR7
Yamaha SRX-6 (x2)
Rust Restorer
Postby Rust Restorer » 21 Apr 2010 18:47
Have a look at my website, on the DHC restoration page and pics, might be of help.
1980 DHC Cashmere Gold
1981 FHC Persian Aqua Blue
www.andys-tr7.co.uk
http://andystr7blog.blogspot.com
Mike T
Postby Mike T » 23 Apr 2010 15:42
just taken the wing off mine for the same issue. Hope this helps (Rust Restorers website was really helpful for me and so was Beans blog)
I ended up go further !
MrT
Postby MrT » 23 Apr 2010 20:14
Ouch! I hope mine's not that bad!
Dale
Agrati Capri (x2)
Triumph TR7
Yamaha SRX-6 (x2)
Users browsing this forum: No registered users and 89 guests
