I made a tool from 1 1/2" wide metal straping. I took the door cards off and then I used a putty knife to push the original clips (The clips have little barbs on one side, so be sure and check the direction of the old clips before you remove them!) off the old strip and collected them as spares.
Remove the old rubber and slide the new one in place at the vent (Hah!) window frame. The trick with putting the new clips on is to push the new rubber all the way into place and then put pressure into the door face and slightly down. With a clip in the proper orientation, you set and pull the new clip into place. Then move down and set the next one. I put them about 2" apart using both the new and old clips.
Before I installed the door cards I made some extensions for the speaker wires, so the next time I remove them, I just have to remove the door light wires and lay the cards on the ground.
PS, If you put foam insulation on the vent window frame, you will cut down of road noise and water comeing into the passenger compartment.
