It might be a stupid question but I keep thinking if the cylinder is bigger then the piston will move a shorter distance per millilitre of fluid that enters the cylinder. After that I get a bit cloudy on what my name so I can't follow that thru with a conclusion.
Do I just need the slaves off a SD1 or do I need a bigger master cylinder?
I don't want to do a rear disc conversion thank you.
Blog: http://www.forum.triumphtr7.com/topic.asp?TOPIC_ID=8548
