Postby Hasbeen » 03 Jan 2008 00:49
I have not posted on this before, as I think the problen I had, with
a 7 pressure plate is very unusual.
If all the usual things fail to fix the problem, or if you have it
out for any reason, have a good look at the pressure plate.
My current 7 had a very similar problem.
You could not get it into any gears, with the engine running, &
could not get it out of reverse, first or second, with it running.
This was after still the case after rebuilding the slave, & master
cylinders.
When I took it out, I, & a few really knowledgeable people I showed
it to, could see nothing wrong with it.
When I took it to an exchange components bloke he showed me that
the groove in the cast iron bit, in which the diaphragm works was
worn. This allowed some lost movement between the diaphragn, & the
cast iron, before the face moved.
It appeared to be working OK, but the face was not drawn back
far to free the clutch plate, in the car. He said he only got a few
like that each year.
It was very lucky for me, for, although it gave me a hard time
finding it, the reason the car had been retired, 4 years before by
the PO, was he could not get the clutch to work. It probably saved
me quite a bit of money, on the price.
