Gear stick banging up and now
Monkeyzak
Postby Monkeyzak » 10 Apr 2017 21:16
Hello
Slowly working through my TR7 trying to fix all the things that annoy me
You can lift the gearstick up and down and it makes a banging noise. It does it when I drive. Any ideas why it's happening? Is something broken or missing? Any suggestions what to check?
Ta
Derek
Re: Gear stick banging up and now
Postby Beans » 10 Apr 2017 21:33
Gearbox extension bushes probably worn or desintegrated :roll:
Some more reading here: http://tr7beans.blogspot.nl/2008/08/dhc-gearbox-check.html
Monkeyzak
Postby Monkeyzak » 10 Apr 2017 21:49
The cars been stored for years so i imagine loads of rubber is stuffed. My mates got a ramp. I'll take it there.
Thanks!!!!
Postby Hasbeen » 11 Apr 2017 09:53
Yep, never bought a 7 yet that had those extension bushes in place.
While you are under there, have a look at the gearbox mount. It is probably more like jelly than rubber, & check there is a spacer, about 2" diameter, 1" thick between the mount & the box. They are often missing.
Monkeyzak
Postby Monkeyzak » 11 Apr 2017 18:45
Parts ordered today.
I'll check out the gearbox mount too.
Thanks for the advice. Can i do this under the car when the cars on axle stands or ramps or do i need a vehicle lift?
Postby FI Spyder » 11 Apr 2017 20:08
I did it all on axle stands.
Postby Hasbeen » 12 Apr 2017 09:17
Yep.
It helps if you have slim hands, & an eye in the end of your index finger would be handy, but I've done 4 of them that way.
Postby dursleyman » 12 Apr 2017 13:12
Just did mine last week and found it easier access with the gearbox supported on a jack then you can take the crossmember and propshaft off.
Postby Beans » 12 Apr 2017 19:30
Removing the gearbox cross member certainly helps to provide more working space.
Just make sure you support the gearbox with a stable jack.
Monkeyzak
Postby Monkeyzak » 13 Apr 2017 06:50
All the bits and my new jack are coming today so might have a go this weekend. I am a complete novice so i confess it sounds all a bit daunting. I need to learn though as this was the deal with the Mrs when i bought the car
Postby Hasbeen » 13 Apr 2017 12:47
We all have to learn, no one is born knowing very much.
You have a lot of people here, who are not only willing & able to advise, but do know an awful lot about 7s.
Postby FI Spyder » 13 Apr 2017 15:52
Couldn't agree more with Hasbeen, learn to do by doing. The job might be fiddly getting the bolts started in limited space but not particularly complex and every body has a first time for every job. I always take pictures before and as I go through a job with an old 1.3 meg camera (you can't take too many) in case you forget how things go, a lesson many here have learned, sometimes multiple times.
Postby dursleyman » 13 Apr 2017 17:04
How did we ever work on cars before digital cameras were invented?
Postby Beans » 13 Apr 2017 19:04
I used to have a small notepad and pencil within reach, for making notes and sketches :roll:
Postby FI Spyder » 13 Apr 2017 20:06
I had a book back in the '70's called "How To Fix Your Volkswagon for The Complete Idiot". It had no pictures, just a few hand drawn line images but it could talk you through a complete engine overhaul even if you never turned a wrench. I pulled out the engine on my bug to change the clutch using a jack some two by fours and a few bricks. Previously I had only did brake job and replaced a few torrington starter clutches on my Javelin and some points/plugs/wires on my '71 Javelin. It was done in a conversational tone with amusing anecdotes that made it a good read even is you weren't working on your car. Very special author. Never seen a book like that since.
Users browsing this forum: Google [Bot] and 43 guests
