I think there is a diaphragm and the big spring to assist return. If the diaphragm split it might give give your symptoms. Best way is to replace it with an upgraded version from S&S or the like. There is also a non return valve in the pipe or connector on the servo which might have failed, but not sure it would give that result.
I had problem with the master cylinder and replaced with a recon unit which leaked so bit the bullet and replace the servo and M/C with an upgraded one from S&S (possibly from a Sherpa van?). Brakes are good now even with the standard disc/drum setup.
Saab 9000 2.3 LPT Auto
