Strut bearing recommendations
TR7Aaron
Postby TR7Aaron » 18 May 2009 16:21
One of the things I want to change on my car is to add roller strut bearings for easier steering.
Does anyone have any recommendations as to what's the best type?
I've read about the Merkur version. I've seen the sealed type on eBay and I've looked at the type offered by TSI automotive.
Prices seem to be somewhat in the same range but I'm looking for something that works the best (smoother steering), doesn't affect ride height, easy to install (no machining), and durability (I will be driving this car so water and dirt will be a factor).
Thanks for any advice you can lend!
Aaron
Postby busheytrader » 18 May 2009 18:02
Hi Aaron,
I bought mine from Robsport and they work very well. Fitting the bearing kit was easy. Refitting all the front suspension which had all been polybushed was not, especially the front roll / sway bar.
As far as I can remember the bearings were sealed. So long as your rubber gaiters / bellows around the struts are in good condition and you have the rubber caps on top fitted, I don't think dirt or water will get them.
Postby john » 19 May 2009 07:43
Fitted the sierra type to my fixed contrary to some reports there is no ride hight difference and at £8 a strut and half to an hour a side to fit can that be beaten
V8Wedgehead
Postby V8Wedgehead » 19 May 2009 12:35
Aaron-Being state side I know of a lot of TR7 and even TR8 that use TSI roller/needle bearing kits for the strut tops. It is a very easy and striaght forward swap. Just make sure everything is clean and well lubed and you should be good to go.
Michael
Postby Beans » 19 May 2009 13:26
I used a slightly different approach with the Sierra bearing ...
http://tr7beans.blogspot.com/2007/05/dhc-front-suspension-upgrade.html
There were a few critics then, but I am glad that I can say that after 2 years and more then 10000km of hard driving (including one 10CR and one LCC) the bearings were still in pretty good nick when I dismantled the front suspension for the restoration of the car.
Postby Chris Turner » 19 May 2009 17:41
When I use the TSI/Wedgeparts kit I put a large O ring around the outside of the bearing to stop dust etc getting inside.
www.triumphtrs.co.uk
TR8 FHC
TR7V8 rally car
Users browsing this forum: No registered users and 40 guests
