to space starter or not to space
motomadness1947
Postby motomadness1947 » 17 Nov 2014 16:19
I have a new upgrade starter from the Roadster factory. does anyone know if I use the spacer between the starter and the engine that was used on the original starter or not.
Thank you
bruce
nick
Postby nick » 17 Nov 2014 17:08
I would call them.
nick
'79 TR7 DHC
'76 TR7 FHC
motomadness1947
Postby motomadness1947 » 17 Nov 2014 17:55
Thanks for the response, but I have called them most of the day and no one from tech is available
Bruce
motomadness1947
Postby motomadness1947 » 17 Nov 2014 18:24
finally talked to Dave the Tech guy at RF. He did not know if it needed the spacer or not. So again I ask, so I do not have to install, try it and have a 50 50 chance of needing it or not, Has anyone installed the upgraded, starter and did you use the spacer or not satisfactorily
Thanks
Bruce
Postby FI Spyder » 17 Nov 2014 18:44
I used the spacer. It's not not very thick so wouldn't make much difference. A friend had used a Honda starter on his Spitfire (straight bolt on) and it was out 1/4" (can't remember if it was too far or not far enough). Seemed to work well enough.
Postby dursleyman » 17 Nov 2014 19:20
Left mine out when I fitted the new high torque starter. No problems.
1981 TR7 Sprint DHC
motomadness1947
Postby motomadness1947 » 17 Nov 2014 21:52
Thanks. I appreciate the fact that it does not seem to make a difference. I believe I will go ahead and install it as then I will have it if I need to replace sometime in the future
Bruce
Postby andyf » 19 Nov 2014 06:12
Obviously doesn`t make a difference as I used mine.
1980 Persian Aqua DHC
Rayjones
Postby Rayjones » 19 Nov 2014 10:03
I fitted mine without the spacer a couple of years ago, no obvious problems with it since, works well
1980 UK BRG 2L DHC
Users browsing this forum: No registered users and 19 guests
