I am 19 years old since February
I own a 1976 TR7 Dual SU HS6 in okay condition... For a 76
All the work I have done so far as follows:
<i>Fuel pump replaced</i>
<i>Gas tank restored</i>
<i>Plugs and wires</i>
<i>Oil pan dropped and cleaned</i>
<i>Repaired main harness</i>
<i>Electronic ignition</i>
<i>Rear brake job</i>
<i>Passenger front brake line replaced</i>
<i>Clutch and slave cylinder replaced</i>
<i>Battery</i>
<i>Parking brake fixed and adjusted</i>
<i>Both calipers cleaned and greased (Fixed dragging brakes)</i>
<i>Carbs rebuilt</i>
<i>Timing adjusts 2 degress ATDC at 800 rpm</i>
When I first drove it, the brakes dragged, so I took of the calipers and cleaned everything up. I did not take out the piston.
I can now press the brakes, and they release. I can push the car around easily (I weigh 140lbs)
When I am in first gear, I can put the pedal all the way down, and it seems like it doesn't want to go above 3,000 rpm easily. Shouldn't the tires slip a little?
I'm a pretty relaxed driver, I know its a weak car, but my lawnmower accelerates faster, and its a push!
Thank you everyone for the constructive posts! I really do love this for, I greatly appreciate the time you guys put into this
Thanks,
Justin P
