Engine Transplant
Engine Transplant
Postby RUDDY » 06 Feb 2009 14:52
All I need to do now is get it to fit ...[:0]
Postby Beans » 06 Feb 2009 15:53
mmm ... should be an interesting conversion [8D]
... but there are other options [;)]
Postby windy one » 06 Feb 2009 16:21
that would be awesome! Are you really going to try????
Postby RUDDY » 06 Feb 2009 16:32
[quote]<i>Originally posted by windy one</i>
Lets just say its in the planning/theory stages, that engine is lined up for another ongoing project but when I looked it I thought 'why not', I have access to another cossie motor.
Postby busheytrader » 06 Feb 2009 19:32
A Cossie in a TR7?
It would be rude not to.[:)]
Postby paul w » 06 Feb 2009 22:38
Bobsport had a 'Pinto'powered wedge once.They fit those 16v lumps into
the 'mighty Mini'!Those that can,do.Ruddy,go for it mate!
Postby Beans » 06 Feb 2009 23:24
... but there are other options ...<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
OK, no progress at the moment due to other "projects" but still on the to do list [:p]
Reddragon
Postby Reddragon » 07 Feb 2009 21:53
Ruddy
If you don't mind my asking, what is the horspower of the Cosworth engine that you are thinking about putting in?
The engine I have out of a Focus with webers and a header should put me in the 160 - 175 range. This will be backed up with a Ford T-5 speed transmission. I plan to still use the stock 5 speed rear axel with the four speed brake cylinders.
The one problem I have at the moment is the oil pan, may still have to buy the one from Retro Ford as that is the only one I see with a rear sump.
Dale
1974 TR6
1977 TR7 FHC
Postby RUDDY » 08 Feb 2009 08:46
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Reddragon</i>
Ruddy
I was planning to rebuild the engine to totally standard spec so that would give it about 210 bhp, should be reliable at that, tickover nicely, was planning to change to cos 4x4 pistons as this removes the inherant piston slap in the earlier design ........apparently. Also planned to use a cossie T5 box or sierra type 9 and the 5 speed TR back end. Think I will probably spend the summer with the car as is and use it whilst gathering parts, if it should go pop tho' [;)] the rebuild will begin. At the moment I have about 4/5 of my mates cars ongoing being restored so squeezing some time in on my own isn't easy.
Couple of pics of current projects
MK1 Bubble arched project, this is probably getting the first cossie engine, built this from a 13k miler, fitted the steel arches etc
This is a mates MK2 Mexico, been rebuilding the front end and removing a few areas of grot, a very nice original early car
This ones next in the que, its getting painted now then wants a concours rebuild
There a 3 other Escort shells awaiting there turn , hopefully will manage to squeeze the TR in somewhere
Postby Chris Turner » 08 Feb 2009 14:23
There was a TR7 in Rotherham a few years ago with a Sierra Cosworth engine, the last time I saw it , it was for sale on E bay.
www.triumphtr.co.uk
TR8 FHC
TR7V8 rally car
grndsm
Postby grndsm » 08 Feb 2009 17:00
Well, it isn't the mighty 4G63, but it should do the trick [;)]
I would immagine that you will encounter a lot of problems that I had to address in my project: www.reitmanracing.com
Beans, what engine is that?
Leon
Postby Beans » 08 Feb 2009 17:37
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by grndsm</i>
...Beans, what engine is that? ...<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
Ford Duratec 2.3 litre ...
http://tr7beans.blogspot.com/2008/03/blasphemy-or.html
http://tr7beans.blogspot.com/2008/04/more-blasphemy.html
grndsm
Postby grndsm » 08 Feb 2009 19:35
Nice choice, Beans! I especially like the oil pan design for a TR7 application. That is one less thing to worry about![;)]
Did I miss a post in the varients forum or you haven't gotten around to it yet? [:D]
Leon
Postby Beans » 08 Feb 2009 20:31
... Did I miss a post in the varients forum ...<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
No you didn't, keep a watch on my weblog.
Not yet sure if the project will go on, first have to finish the DHC.
Will do some serious measurements in one of my spare body shells after that (engine is meant for 't Kreng, being my trash car [:D])
Users browsing this forum: No registered users and 80 guests
