FAN BELT CHANGE HOW DIFFICULT??
Postby tr7inc » 11 Dec 2008 08:15
Hi guys, just thought as im waiting to replace my old Radiator, and as ive done most of the work on my 7 on my own, just was gonna ask a daft question even though i have referred to the manual, is it difficult to change the fan belt?, never ever changed one and whilst the rad was off i thought id kill to birds with one stone.
Many many thanks as always, id be lost without you allImage
Postby andyf » 11 Dec 2008 08:34
Absolute piece of cake. Just loosen off the alternator bolt on the adjustable bracket, push the alternator towards the engine to loosen the belt, then pull it off the pulleys and replace.
Refitting is the reverse. Just make sure the tension is correct. It should only take you a few minutes to do.
1980 persian aqua DHC
davesopener
Postby davesopener » 11 Dec 2008 12:09
hi,
even ive changed the fan belt!!!!
without any problems!!!
changing radiator much more complex task.
good luck
dave[8D]
Postby john » 11 Dec 2008 15:02
easy peasy losen off the alternator bolt whip off the old belt, put on the new yank over the alternator with a bar or a long screwdriver and hey presto done oh yeh tighten the alternator bolt back up
There is probably a more technical description of the event but hey thats how i see it
Postby tr7inc » 11 Dec 2008 18:41
Many thanks guys, as always youre help is so gratfully recieved, having sezarched my garage over & over im sure i had a brand new belt, in fact the one i had was also able to fit a Cavalier if memory serves me correct, which modern day belt is prefered?
Many thanks as always
Postby Rich in Vancouver » 11 Dec 2008 19:20
My only caution is not to put too much tension on the belt.
It would be a shame to pooch your alternator bearings.
Just do it up tight enough that it doesn't slip.
Rich
Postby tr7inc » 11 Dec 2008 20:41
Many thanks Rich, i will have a gol at changing mine once i have purchased a new belt.
thanks again
