eBay Punt - new brake MC
omichaelshar
Postby omichaelshar » 01 Nov 2008 03:49
I just took a punt and bid on a PBR Holden Commodore (VB VC VH VK) Brake Master Cylinder and got it for the starting price of AU$100 (US$66 / GBP41).
I think it is the same unit that was used in the following conversions:
Time will tell...
Owen
john mc nulty
Postby john mc nulty » 03 Nov 2008 11:33
Will the master fit on your existing booster or are you using another booster.I got a bit of info off someone off the site see attached..............
I bought the system off Triumph Rover Spares in Adelaide as I did not know exactly what was required (ie what model etc), just that it was a Commodore set up. Now that I have it I can tell you it is from a V8 VS Commodore and it fitted up exactly.
The master cylinder is a bog standard PBR 15/16" model which you should be able to pick up new for not much money from Repco etc, and I wouldn't think the booster would be too expensive either. You need to remove the proportioning cylinder from the suspension turret and bend a few brake lines, but that is it.
The brake warning light wiring hooks up as well if memory serves me well, but I couldn't get the light in the dash to go off (the brake fluid level light) and couldn't be stuffed trying to trouble shoot the problem so just undid the bulb half a turn and, voila! No more annoying light...one day when I have a lot more time I will figure it out.
Hope that will help out Owen
omichaelshar
Postby omichaelshar » 03 Nov 2008 20:01
Thanks John.
The MC I have purchased is a bog standard PBR 15/16" model. I am still seeking a booster, but will now limit my searches to VS models.
Were you able to ascertain if TRS made any mods to either unit?
Owen
john mc nulty
Postby john mc nulty » 03 Nov 2008 20:36
Hi Owen not sure if TRS made any mods to it I have tried a VS V6 AND A VR V6 booster with no luck so it would need to be the VS V8 booster.
omichaelshar
Postby omichaelshar » 03 Nov 2008 20:50
OK - Thanks John for this advice. It's low on my priorities, but I will keep looking. I feel a trip to pick and pay less may be on the cards.
john mc nulty
Postby john mc nulty » 04 Nov 2008 04:55
I have a booster from a SD1 that I am going to use the master cylinder looked like it had been leaking so just yesterday I have tracked down a repair kit for it here in Adelaide.So it looks like I will use that one.The guy I got the information is in Alice springs he uses the name Craig c on this forum you could contact him he might have some more Information.
