Internal Fuel Pump
Internal Fuel Pump
Postby Wayne S » 23 Oct 2008 22:48
Copied from a mate of mines posting on another forum:
My mate has a problem, he has an SD1 sender unit and internal fuel pump but he doesnt have the wire that goes between the two.
Is it a special type of wire...we thought it should be because of the fuel melting the insulation?
anyone any ideas?
Can you help?
Postby john 215 » 26 Oct 2008 18:09
Hi Wayne,
I dont beleive that special wiring is required, BMW E39 (5 series)this is a common failure point on them, the connector breaks off the wiring and have replaced a few over the years with no repeated failure or worse a fire [:0]
Try these guys i have used them with all the wiring on my V8 conversion-
http://www.autoelectricsupplies.co.uk/
Or these guys on this SD1 forum-
http://www.roversd1club.net/forum/default.asp
