Hypoid Differential Fluid
kermit
Postby kermit » 09 Jul 2008 17:17
Anybody in the states know where I can buy hypoid differential fluid for my TR7?
80 TR7 DHC with ZS Carbs
Brooklands Green
MickeyR
Postby MickeyR » 09 Jul 2008 18:19
Got mine (Lucas brand, I believe) at Auto Zone. Just check the label carefully.
Mickey
Postby FI Spyder » 09 Jul 2008 18:27
I've topped mine up with Pennzoil synthetic differential oil which is supposed to be good for yellow metal as well. Compatible with older types of oil. You can go to their website to see pcture of what the bottle looks like. (They have many different types of oil.) You should be able to get it ay any auto parts store, Auto Zone, Pep Boys etc.
humanoid
Postby humanoid » 09 Jul 2008 20:51
Will Mobil 1 75w-90 gear oil work as well?
_____________________________________________
<h3><b><font color="orange">1980 Inca Yellow TR7 Convertible</font id="orange"></b></h3>
Postby Beans » 09 Jul 2008 21:08
Use a decent brand and make sure you've got the correct specification.
For the 5-speed axle that should be a hypoid oil meeting one of the following specifications API GL4 or MIL-L-2105/NIL-L-2105B or BLS 22.0L.03
kermit
Postby kermit » 10 Jul 2008 01:26
Thanks guys.
It seems like this Lucas product should work.
http://www.lucasoil.com/images/medialib ... ar_oil.pdf
Brooklands Green
MickeyR
Postby MickeyR » 10 Jul 2008 01:56
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by kermit</i>
Thanks guys.
Brooklands Green
Yep - that's the one I bought!
Mickey
Postby Hasbeen » 10 Jul 2008 02:54
When I was a young bloke, in the 1950s, living in the Oz bush, in
the quiet of the night, you could often tell there was a car comming
by the howling. No, it wasn't their tyres, or our dogs, or even the
cat, it was the cars diff. You would hear that motoring sound, long
before there was any hint of engine noise.
Fortunately, for you young blokes, it's a sound long gone from
motoring, due to closer tolerances in diff construction today.
However it was still with us loud & clear into the late 60s.
In Oz, our trusty used car dealers had discovered that you could
stop the howling, at least for a few hundred miles, by stuffing half
a dozen banana skins in the diff. You needed a strong stomach to be
a mechanic back then, doing oil changes, because the smell of EP90
oil, & old mashed banana skins has to be experienced to be believed.
About 1963, enter STP in Oz, & all that was gone. The dealers
discovered that STP added to the diff not only did a better job of
qiueting the diff, it even reduced their leaks, made them last
longer.
After doing the 1964 Bathurst 500 in a car using SAE10 oil, with
15% STP, I was impressed. After finding it made the Big end bearings
in my Triumph TR3A engined Morgan +4 last 5 times as long, when
racing it, I was more impressed. After running it in the Hewland
transaxle, in my Brabham F2 open wheeler, & finding it eliminated
the "scalding" type wear on the crown wheel teeth, I was even more
impressed.
I have not run an engine with out 10% STP since.
I have not run a diff without 15% STP since.
I tried it in a Moss XK120 Jag gear box once. It eliminated the
sincros, which depend on friction to work, completely. Not good.
I don't run it in gearboxes.<s></s>
If you are still with me after all this, unless you have a limited
slip diff, stick 15% STP in your diff with that oil, & your diff, &
your bank a/c will thank you.
kermit
Postby kermit » 10 Jul 2008 12:12
Hasbeen - That is a great story.
I will give it a try.
Brooklands Green
Postby bmcecosse » 10 Jul 2008 20:30
Yep - stocking up on the bananas tomorrow - great idea!
Postby Hasbeen » 11 Jul 2008 01:24
Don't forget you only use the skins, so you get to eat the benans as
well as "fix" your diff.
Postby FI Spyder » 11 Jul 2008 06:18
Back in the day in central Manitoba banana skins were hard to come by so people added sawdust.
Postby Beans » 11 Jul 2008 21:12
Used to be a normal fix on the rather indestructible Peugeot 404.
Just put grease and saw dust in the differentials and forget
Users browsing this forum: No registered users and 697 guests
