Why Chrome?
Why Chrome?
Postby jclay (RIP 2018) » 09 Apr 2008 16:27
Does anyone know why BL put any chrome on the TR7/8s at all? Just the windscreen trim, antenna and luggage rack. I feel it should have all been black. Door handles are aluminum, but on the Range Rovers, they used the same handles, but in black.
Just wondering.
Postby Beans » 09 Apr 2008 16:43
nothing wrong with a few polished stainless trim pieces ...
Postby Odd » 09 Apr 2008 17:58
On my Midas gold '8 I've changed out the door handle units to the all black version (from the Discovery)
- and without the key lock in the passenger door. Looks the part I'd say.
Haven't dared go keyless in the drivers door yet, but I have it stashed away for when I do. (I don't trust
the keyless entry kit to be 100% failure proof yet...)
Next step I guess is to powder coat the luggage rack and antenna foot black.
The windscreen strip is a tougher case as it's stuck in that glass fastening goo. Will have to wait until it's
time to brake loose the glass...
The three versions of door handles:
All black, Discovery rear door handle fitted to passenger door in the ´8:
92rrrandall
Postby 92rrrandall » 09 Apr 2008 19:36
This photo does not do it justice; but I just sanded it with Scotchbrite and then sprayed it with Duplicolor Trim Paint. Easy to do and maintain.
Randall
Postby stevie_a » 09 Apr 2008 20:12
<font color="purple"><b>I changed my door handles to Morris marina rear handles <u>no</u> keyholes </b> </font id="purple">
Image Image Image
92rrrandall
Postby 92rrrandall » 09 Apr 2008 20:26
mikehardwick
Postby mikehardwick » 09 Apr 2008 21:29
Hey, Randall - where did those cool - er, sorry, kewl - door mirrors come from? You've probably told us before, but at my age, the old memory, you know.............
Mike
1981 TR7V8 DHC
TSSC N. Yorks A.O.
Postby paul w » 09 Apr 2008 21:37
Never could understand British Leyland thinking when it came to the
cosmetics.Certainly some parts were made for the 70's,esp.the early
tartan cloth in the lurid greens and reds.The strip around the wind
screen sticks out,surely should be black like Odd and Randall say.
The wedge is a modern design,why put chrome on it - to please the
'old school' Tr6 brigade? Did'nt work,did it! Having said that,Beans
fhc looks good with the extra brightwork and its ok to me on my v8,
must be something to do with dark body colours,yet on my white auto
i think it'd be better black,so thanks Randall for the tip - i'm off
in the morning to buy some 'Rattle cans'!!
Postby stevie_a » 10 Apr 2008 06:20
<b><font color="purple">Randall Where are your window wipers?
I could not work out why the window looked so uncluttered </font id="purple"> </b>
Image Image Image
Postby Underdog » 10 Apr 2008 13:04
Randall, I like the look. Wish I had done that before having the WS installed. I also like the hidden wipers or are they missing?
92rrrandall
Postby 92rrrandall » 10 Apr 2008 15:04
Not driving this car in the rain; and if it does rain then I have RainX on the windshield. Have to reinstall them for safety inspection.
These mirrors are much better than the original type. The mirrors are K-Source part# 0601 which I bought off the shelf at Autozone, or http://www.jcwhitney.com/BLACK-FLAG-STY ... _10614.jcw
I made two 1/2" thick plastic mounting pads with two holes for attaching the mirror. On the window side of the mounting pads there is mounting tape. This is foam material with VHB acrylic adhesive on both side of the tape. Mounting tape is pricey but is amazingly effective. The window glass is not flat so the foam tape is required.
You can buy black radio antennas that are a direct replacement.
Have not yet painted or replaced the door handles with Discovery handles. But they are not chrome. Too much work to replace right now.
Also I replaced my luggage rack with custom made plastic pads with cover the holes until my next paint job. Have I ever mentioned that I own a machine shop that specializes in plastics?
Randall
moestr7v8
Postby moestr7v8 » 10 Apr 2008 23:13
Hi Randal I also like your door mirrors what is the trade name for the foam pads you used as if I can get it or equivilant in UK I would like to change the original mirrors to the type on your car.
Regards Moe
92rrrandall
Postby 92rrrandall » 11 Apr 2008 06:09
Let me try again explaining what I did to attach these mirrors to the glass:
I made two 1/2" thick plastic parts to bond to the side windows. I used VHB(very high bond)mounting tape to attach the plastic parts to the windows. 3M makes mounting tape and you can find it in the adhesive section of a hardware store. The plastic pads have threaded holes for screwing the mirror base to the pads.
If you have access to a machine shop you could make the pads out of aluminum. If you have access to woodworking equipment you could make the pads out of plastic material. Just make a paper pattern and then do some cutting.
Randall
XSeries
Postby XSeries » 12 Apr 2008 11:21
I can't think of any chrome on the TR7 or 8 - so the answer is that it was only done to a few cars. The windscreen surrounds are stainless steel not chrome. There was an early experimental injected drophead (13E engine series) that went to the US (Az) and Canada for hot and cold weather testing that had the lower panel chromed to (sort of) match. Thankfully that was never taken on, as it looked overly bright!
B
Postby jclay (RIP 2018) » 12 Apr 2008 12:02
Chrome, Shome! You know, that shiny stuff!
Users browsing this forum: Google [Bot] and 94 guests
