gearbox mystery
Sautie
gearbox mystery
Postby Sautie » 30 Jun 2016 15:05
my daughters 7 got stuck, fortunately at home, in gear.
The first mystery when removing the drain plug was that no oil came out. Examination of the underside of the car revealed no oil on propshaft or underbody( I have a pit). The painted garage floor shows no evidence of any oil leak.So remove the gear box. Examination of the outside of the gear box shows no oily marks , only road dirt, from our sand road.
Strip the 5 speed box and the mystery deepens everything is bone dry. Yes it had jammed first and second gear but there is no damage to any of the gears, bearings or synchro rings and nothing even has sign of any bluing however faint. The car was serviced 4 months ago and the box was filled with ATF using a long flexible tubed hand pumped filler. Each part of the box has been critically examined and show no signs of oil any where on the outside of the box. Even the outside of the rear oil seal is dry.
Now she had just driven 60 odd Km to my place and the gear box stick happened as she pulled up a slight rise into our yard. She had switched off and come inside and on returning to her 7 switched started the engine engaged first and nothing happened other than stalling.
So there is the mystery , where did the oil go and why no damage?
Re: gearbox mystery
Postby john 215 » 30 Jun 2016 15:18
WOW what a mystery :shock: The drain plug is still in place or for that matter the level plug, not first time I have seen them fall out :cry: Surprised no damage though.
Sounds like the box is now stuck in two gears, this will lock any manual gearbox solid and is a common method of undoing any nuts or bolts on the shaft themselves in most gearbox's.
Re: gearbox mystery
Postby FI Spyder » 30 Jun 2016 20:14
Did you see them actually fill the gearbox with ATF? Reminds me of a story of a guy (he reupholstered my couch) that had an Austin A40. Had $3,000 of work done on it over the winter. Come spring he takes it for a ride only to see his front wheel come off and roll on ahead of him after 40 or so miles. They forgot to grease the wheel bearing (it was dry).
Re: gearbox mystery
Postby Beans » 30 Jun 2016 21:26
Did you service the 'box yourself?
Re: gearbox mystery
Postby dursleyman » 04 Jul 2016 16:27
Don't know where that ATF oil went but it doesn't sound like it went into the gearbox!
