Back to black
penlost
Back to black
Postby penlost » 04 Mar 2016 14:23
I would like to re paint the quarter window reveals and door handle surrounds in black but lack a bit of confidence ! Do I just mask around and spray them where they are? Or hand paint them ?
Re: Back to black
Postby FI Spyder » 04 Mar 2016 16:08
If you do it's going to look like a cheap Maaco paint job. I'm pretty good at taping and masking but there are times and places for that. Take them out. Now is the time to remove things from the door. Grease moving parts in latch/lock/window winding mechanism. Replace outer window seals if needed. The quarter window frames come out with a few nuts. A couple rivets and it comes apart so you can remove the window and rubber seal. Clean window, treat/clean rubber seal with something like Maguire's Vinyl and Rubber Cleaner and Restorer. Sand any paint flaking to feather edges (paint hides nothing). Make sure paint is clean, I like to clean with a water based cleaner. Paint with satin trim paint (sticks to bare metal, chip resistant). The door latch comes apart too. I'm a believer in if you are going to do part of a job, take the time to do the whole job so you don't have to go there in a year or two to do something else. Hows your door cards. If they are warped from moisture/water, VB had door cards with aluminum reinforced top third with replaceable window seals, not exactly stock but an important upgrade in quality.
fastman
Re: Back to black
Postby fastman » 05 Mar 2016 16:02
I had my door pulls powder coated for durability along with the window trim and boot lock as per forum advice. I'm very happy with the result. As for painting other parts, I also used the "trim black", again happy with the result.
TR7 FHC
Users browsing this forum: No registered users and 71 guests
