Reverse Light Switch
smoking joe
Postby smoking joe » 03 Apr 2015 16:58
Just a quick one.
Reversing lights never worked in my ownersship, 18 months, looked at the switch, only one terminal, nothing like std. part. I had assumed it would work like door contact, with operation of switch making earth connection.
The terminal has a neat plastic covered female connector and nothing else, were single ones like this ever fitted ? cannot find in parts cats.
Alternatively there is a loose wire with connector nearby with scotch lock to side, but nothing to connect it to. The car is quite original..
1980.DHC
SJ
smoking joe
Postby smoking joe » 03 Apr 2015 18:46
Don't worry sorted.
Postby john 215 » 03 Apr 2015 19:06
Cant say I have ever come across a reverse light switch you describe. In standard form they are a two wire switch with a plunger that completes the circuit when pushed down by the selector mechanism, a very generic switched used on a lot of BL cars of that age.
Normally with green with a tracer wires connected. Possibly the wire you mention with the <b><font color="red">FIRE STARTER </font id="red"></b> or more commonly called a scotch lock ( hate those things, should be illegal IMHO [V] )
Users browsing this forum: No registered users and 27 guests
