Cigarette lighter
claypole1360
Cigarette lighter
Postby claypole1360 » 20 Dec 2014 13:09
So my standard cigarette lighter in the car will light a cigarette but won't run the charger for the satnav. (I don't smoke). So I bought a modern cigarette lighter and fitted that and hey, the satnav won't work on that either, help?
1978 TR7V8 FHC
1962 Herald Coupe 1200
1989 Peugeot 205 xs
2003 Peugeot 206 GTI
2009 VW Passat
supercass
Postby supercass » 20 Dec 2014 14:12
Are you definitely getting power with your new charger? IIRC there were two different type of bases for cigarette lighters (the part that inserts into the dash receptacle was a slightly different shape.) Sometimes they come with an adapter in the shape of a metal ring that clips around the base to enable it to fit both types. Fitting older cigarette lighter powered charger / devices was often a problem with later European cars Also can't recall if the live to the cigarette lighter was permanently live or controlled by the ignition. supercass
Postby FI Spyder » 20 Dec 2014 17:08
My Magellan GPS charger works fine in my Cig. lighter, as well as phone charger. As an aside I wanted the GPS mount that clips into dash vents, Magellan wanted $49 for it so I went to eBay and got two for about 3 or 4 bucks each out of California.
Postby saabfast » 20 Dec 2014 19:49
Probably done it, but have you tried waggling it about a bit? My Garmin works fine but is a bit loose in the original socket. I found that changing into 1st and 3rd tended to knock the plug and disconnect it, sending the satnav into a power down mode. I got a cheap 3 way plus USB adaptor from ebay which has a much shorter plug and thinner with to the outlet box. It is much easier as the shorter plug does not get knocked and the box sits on top of the dash, avoiding the thick satnav cable running down the dash as it just lays on top with it.
Postby FI Spyder » 21 Dec 2014 01:39
Brings up the other point. The tightening of the socket leaves something to be desired. When I plug it in I give it a twist to tighten it as I plug it in. I tied the excess cord to the power plug to keep things tidy. It is a little tight shifting into third but one just drives around the shortcomings. Just like a Ferrari.[8D]
Postby john 215 » 21 Dec 2014 07:58
More often than not there is a fuse in the adaptor for Sat Nav's phone chargers etc. If you can un-screw the adaptor then have a look they are normally small glass type, a few amps in rating ( less than the car fuse ) and sit behind the metal live feed, worth a look.
Users browsing this forum: No registered users and 16 guests
