Still won't start *sigh*
scribe
Postby scribe » 10 Apr 2014 06:20
Ok, I'm a fairly practical person, but new to tinkering with engines beyond oil changes.
The TR7 won't start :(
1) New plugs and leads, gaps have been set and spark seems good.
2) New in-line fuel filter and fuel pump (couldn't get the old pump open to check condition so just replaced it).
3) Fuel has been drawn into the in-line filter so I assume the pump is working. Fuel looks clean.
4) Fires up for a fraction of a second with starter spray, and then dies.
Still won't start. What are the next steps?
It has sat for about 10 weeks since it last ran, and admittedly took a good bit of turning over before starting that time.
I assume next steps are to open up the SU carbs, and check the needles aren't blocked?
The float bowls don't seem to be weeping fuel so I shouldn't need to look there should I, or are they worth checking too?
Any advice appreciated.
Regards
Chris
PS - some of you may have seen my other thread where I was thinking of selling it. Frustrating as this problem is, all the tinkering has made me want to keep it [:)] for another month or two at least [;)]
g4zur
Postby g4zur » 10 Apr 2014 07:05
Hi Chris
I had the exactly the same problem. Sprayed wd40 into carbs and fired for a second, My problem was caused by blocked jets and the feed from the jet in the bottom of my float bowls, Where the jet screws in.
All caused by rust from petrol tank, Read an article I posted a few months ago, I kept changeing the fuel filter but had to change tank in the end, "Fuel" for thought Chris.
Regards Gareth.
G.P.Albrighton
Ianftr8
Postby Ianftr8 » 10 Apr 2014 07:12
Morning Chris,
Is the battery fully charged? with a little voltage drop things can be a little weaker.
Try hooking it up to a running car on Jumper leads and see if that helps.
Ian
Ian Freeman
1979 TR8 DHC KDU 315V Poseidon Green
Triumph Courier
Triumph owner for 32 years
scribe
Postby scribe » 10 Apr 2014 07:16
Cheers Gareth, I'll take a look.
Ian, it's a brand new battery that's kept fully charged (missed that off my list of points).
Postby dursleyman » 10 Apr 2014 07:41
These things are often something small so don't give up just yet and let someone else enjoy the car in the coming summer.
After it has been turning over for a while and not fired up the plugs should be wet with fuel, be worth checking if they are. If they are not then Gareth might be right and you have a blockage in the carbs. The float chambers should also be full. That would be my next step.
1980 TR7 Sprint DHC
Postby Hasbeen » 10 Apr 2014 07:54
These cars have a high voltage ignition supply while cranking, to help the things fire, but a normal voltage supply once running. Perhaps the latter is not working.
You would be better using an ether based diesel cold start spray, rather than WD 40, which is only a white spirits carrier. In Oz we have one called "Start Ya Bas**rd", which works quite well.
Postby TR Tony » 10 Apr 2014 10:39
You can take the tops off the float bowls to see if there are any rust particles in the bottom - if yes then this may be blocking the pipe to the bottom of the jet assembly, or the jet itself.
You don't mention if you have checked the timing - you have a good spark but might be worth static checking the timing. Are you using points or have you got electronic ignition?
scribe
Postby scribe » 10 Apr 2014 13:01
Thanks.
Re: Points or electronic - actually I actually have no idea, didn't ask when I bought it, nor have I looked [:I]
Is there a guide you can point me at for static checking of the timing?
Remember; I'm learning..... and quite willing to get my hands dirty. In fact you should see the state of them right now (ditched the gloves after they kept getting snagged in the bolts I was doing up). Not very fitting for my office job [:)]
Postby Hasbeen » 10 Apr 2014 13:58
If you really have to keep your hands clean, get a box of surgical/hospital disposable gloves from a chemist.
They cost pennies stand up well, don't get caught, & are thin & tight enough to give good feel.
scribe
Postby scribe » 10 Apr 2014 14:29
I had a box of cheap ones from halfords, but aren't skin tight. Annoying things that rip easily.
I'm picking some proper ones up tonight :)
Postby FI Spyder » 10 Apr 2014 15:34
I second Hasbeen's ether based starting fluid. If there's spark, it's going to start on that. Once it's turning over it's easier for it to continue running on regular gas unless the air/fuel ratio is really rich or lean in which case you have to turn to fuel situation.
French horse dentist
Postby French horse dentist » 10 Apr 2014 18:15
I would have thought that if it fires on gas it isn't electrical. I would say fuel or lack thereof.
Why did I buy this?
Postby FI Spyder » 10 Apr 2014 19:30
Check the rubber motor mounts and make sure they haven't separated. On our trip to California the other TR7 won't start the morning after first layover at Lake Quinault. Took us all morning to try to start it till some one saw the intake manifold move. I hit my forehead with palm and said Zip tie it up and it started fine for the rest of the trip.
Postby dursleyman » 10 Apr 2014 19:45
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by French horse dentist</i>
Why did I buy this?
Don't forget its a ballast ignition system. The ignition feed when the key is held in the "start" position is the full 12 volts but it changes over to the ballasted feed when the key is released to the normal "running" position. Could be a problem with the ballast side so it will fire but not run. Its the same system on lots of cars from this era, not just the TR7.
1980 TR7 Sprint DHC
HDRider
Postby HDRider » 10 Apr 2014 21:51
You can bypass the ignition circuit by using a jumper wire from the battery to the coil to test the harness/switch.
Edward Hamer
Petaluma CA
