How hot to warp head?
trekcarbonboy
Postby trekcarbonboy » 14 Jan 2014 18:16
I recently realized that the minor leak that I thought was coming from the intake manifold o-ring is actually coming from between the head and block. Which begs me to ask how hot does the engine need to get to warp the head? Fortunately no water in the oil or vice-versa.
I installed a new radiator a few months ago with an electric fan. In testing to see when the fan would actually kick on it was at about 7/8ths on the temp gauge. I don't have a way to test the actual temp but the sensor was rated to activate at 185 degrees. Is this too high or was it perhaps a faulty sensor?
I'm pondering the fact that this may have caused the leak and am hoping the head is not warped. Hopefully its just a coincidence that its leaking now and there's no real problem. Either way the head is coming off to hopefully just replace the gasket.
I had the head off 10 years ago and hopefully it's just as easy this time. Will also be installing a manual fan switch.
Any thoughts would be greatly appreciated.
After proof-reading this post before posting it's apparent that I am quite "hopeful". [:I]
Craig '75 2.0 FHC
Postby saabfast » 14 Jan 2014 18:46
185 deg is 85 deg C so not too high, around thermostat open temp. If it is a very small leak a torque down of the head might do it but probably better to change the HG before it goes any further and the wrong things mix.
Saab 9000 2.3 LPT Auto
Postby FI Spyder » 14 Jan 2014 19:25
Pay the extra money for a quality head gasket like a payen rather than a cheap generic one. It'll cost $20 more but worth it. BPNW is out of stock but maybe not for long. Example:
http://www.bpnorthwest.com/triumph/tr7-tr8/engine-gaskets-seals.html
You can get infrared thermometers pretty cheap these days at the discounters and on sale. Cheaper than a machined head.[:p]
You won't know for sure until you get the head off and do a close inspection and put a straight edge on it. The gasket could have just given way.
Postby john 215 » 15 Jan 2014 05:13
You should be ok, but if do pull the head and need to skim it there are thicker head gaskets available.
I have always run a manual override switch on my fan's on the 7's I have owned. On my DHC the fan is controlled by switching the earth on the relay, I use a sensor in the top hose and a A/C switch in the centre console ( car not actually fitted with A/C ) so avoiding a non standard switch !
Postby windy one » 23 Jan 2014 16:22
Quite possibly may just be faulty head gasket. I am having a similar prob. Original head gasket started weeping. Im just going to pull the head and replace the gasket (with the thicker one as per Woody). I have no water in oil or vise-versa. Good Luck!
Users browsing this forum: No registered users and 20 guests
