pcd question
shoveitpusher
pcd question
Postby shoveitpusher » 28 Oct 2013 07:15
i'm in the process of selling my chevette rally car and have a few sets of wheels that would be quite handy for my next project - i fancy a tr7 for some historic rallying.
question is
is it feasable to convert from the standard TR pcd to 4 x 100?
Postby TR Tony » 28 Oct 2013 08:25
Is that the same as the Ford PCD? If so you could take a look at these:
http://www.ebay.co.uk/itm/Triumph-TR7-T ... 2a1a9eea93
Alistair Flack does a lot of other uprated parts for the rally TR7 as well, based on what he has developed for his own car.
shoveitpusher
Postby shoveitpusher » 28 Oct 2013 08:46
not ford - that's 4 x 10,8 but along those lines yes. thanks for the link.
V8Wedgehead
Postby V8Wedgehead » 28 Oct 2013 09:25
You can convert to 4x100. It is actually pretty simple. Get an oversized stud with a wide base like .625". You open the holes up outward using the inside edge of the stud hole and it is just enough to make the 4x100 pattern.
Michael
1980 TR8 FHC #0020
Postby bmcecosse » 28 Oct 2013 18:23
Please NO!! Wheels are safety critical- not something to bodge about like that....... I really do hope this was posted in jest......
paulheritage
Postby paulheritage » 28 Oct 2013 21:58
My TR7 rally car uses Ford wheels so would think you could use a similar period wheel, although suspect it would be easier to buy the correct PCD wheel for the TR7 fitment. If you intend to enter rallys you should check the wheels you have would be eligible.
Cheers Paul,
1976 TR7 2.0 FHC, ACG 3115 - Java Green (on the road)
1977 TR7V8 3.9 FHC rally car, ACG 35005 - Tahiti Blue (complete, no MOT)
www.TR7.co.uk
shoveitpusher
Postby shoveitpusher » 29 Oct 2013 06:25
my wheels are 6" so legal for anything i might do - wheels are effectively free. the only other rule i know of is bolt on pcd adaptors are not allowed, which would be the easiest way to make the change.
reason i want to do this as i have 3 and a half sets of the 5 x 100 wheels, it would be easier to use the tr pcd, but if i sell what i have, i might just get a single set of tr wheels. whilst we may do some shows, the car will be very much for club motorsport so a selection of tyres is quite handy.
like the idea of using a bigger stud and offset drilling the holes. will look into that a bit more.
i agree wheels are a safety critical item but being an engineer kind of helps the bodge at least be done with some element of science. 10 years in vehicle design and manufacturing also helps.
at present this is an idea, i haven't sold my chevette yet and haven't got a TR, i will probably be asking about brakes, dampers, spring rates and lsd's if things come off as i hope.
V8Wedgehead
Postby V8Wedgehead » 29 Oct 2013 08:53
There are about 3 TR8s running in SCCA that have done the 4x100 pattern on the stock hubs. Never an issue. Just the horrid wheel bearings problems even with the slightly larger upgrade offer stateside.
Michael
1980 TR8 FHC #0020
Users browsing this forum: No registered users and 22 guests
