Brake fluid in the cockpit?
tracie
Postby tracie » 22 Mar 2010 19:44
Have been enjoying driving Tracie on dry days now the weather is getting a bit better.
Just putting her away last night only to discover brake fluid running down the clutch pedal onto her carpets
Has anyone else had this problem?, could it be running off the brake system or could it be the clutch, although that seems to be working fine,
The brakes do need attention i have noticed that she needs new brake cylinders and shoes as one side leaks slightly,this is being done on saturday,do you think this could be the problem?
Grateful for any comments
Thanks
Ray
Postby Beans » 22 Mar 2010 20:14
If the fluid is running down the clutch pedal,
the clutch cylinder would be the first thing I'd check.
Bobbieslandy
Postby Bobbieslandy » 22 Mar 2010 20:24
Mine did this, it was coming from the clutch master cylinder. the Clutch will work ok until the level drops so far then a huge slug of air will get into the system. depending on the severity of the leak you might find the biting point is getting near the bottom of the pedal, some of the fluid operates the clutch but the rest goes past the seal and onto your carpet. use the search function, i'm sure there'll be a thread on it involving lots of upside down action in the footwell! Oh and when you change the seals, check the bore of the master cylinder for wear, scoring or sharp bits left over from when it was cast, admitedly never seen this on a 7 but have a few times on land rovers (same setup) remember to wear gloves, brake fluid plays havoc with my hands and to lubricate the seals with brake fluid when re-assembling it.
Think the seal kit was a fiver ish
Rob
tracie
Postby tracie » 22 Mar 2010 20:52
Thanks for the advice
will check the items mentioned
will let you know
Thanks again
Bobbieslandy
Postby Bobbieslandy » 22 Mar 2010 20:55
in the mean time check the clutch fluid resoviour (think i spelt it right?!?) and top it up if it needs it. just need to use DOT4 brake fluid. nothing too fancy.
Postby busheytrader » 22 Mar 2010 21:21
I've had my 7 long enough to have refurbished the clutch master cylinder twice. The rubber inside perished both times dropping fluid directly on to my left foot ruining whatever shoes I was wearing at the time.
IIRC, as per Rob, it's easier to remove and replace the clutch master cylinder with the hood down. Why? Well, if you're lying on back with your head under the dash, your legs have to go somewhere.....
It's easy to rebuild the cylinder and the kit is only a few pounds. It's no more difficult than fitting a new cylinder.
Bobbieslandy
Postby Bobbieslandy » 22 Mar 2010 21:42
What i would of given for a hood to drop when i was doing that, even a sunroof to stick my legs out of! My neck's never been the same..
Postby Hasbeen » 22 Mar 2010 23:07
A little tip for old blokes, [& I should know], working in
footwells. There is no way I can get into there, with my feet up
over the seat these days.
Get a box.
In Oz, the plastic crate that holds a dozen 2L plastic milk bottles
is just the same height as the top of a TR7 cill. I put the box
beside the car, with 8 thicknesses of an old blanket on the box, &
across the cill, to pad the sharpish edge.
Sit on the box, facing the rear, & roll back across the cill, into
the foot well, diagonally. If I am expecting to be a long time, I
might take the steering wheel off first.
This leaves the seat free for you to lay out the tools you may need,
on a cloth on there. They are not that easy to fumble for there,
but it is easier than fumbling around under your butt.
Spectatohead
Postby Spectatohead » 23 Mar 2010 00:01
Get a box.
That's brilliant! I wish I'd have thought of it before I had to get down there while changing my clutch master last winter. Not only am I older, than I was back when I put my feet up over the seat, I am much thicker. I could not get into the position now to save my life. I draped myself over the sill and craned my neck badly but I did eventually get it done, I just ached for a few days.
Jim Clark
'80 TR8
'97 Maxima 5spd
Postby jclay (RIP 2018) » 23 Mar 2010 01:39
[url="http://web.mac.com/jclaythompson/iWeb/Site/Clutch%20Master%20Cylinder.html"]Clutch Master Cylinder[/url]
Postby nervousnewowner » 23 Mar 2010 11:24
only just rebuilt the master and slave cylinders on my car, piece of cake...[:D]
Postby Underdog » 23 Mar 2010 13:12
I've rebuilt mine twice. It developed the drips after being off the road for 6 years. Fortunantely, I use DOT5 in everything. So all it did was put a shine on my left shoe.[:D]
Jim Underwood
Postby FI Spyder » 23 Mar 2010 16:42
For any extensive under dash work like clutch cylinder etc. I take out the seat, 4 bolts and it lifts right out (with top down.) Possibly blankets/sleeping bag to ease the uneven floor. On your back with feet up over the back it's kind of comfy. Better than a crick in the back.
laskaboots
Postby laskaboots » 23 Mar 2010 16:42
oh boy! Now you also get to go through the clutch bleeding procedure
that so much has been written about in the last few months.
Better review that and please let us know how it goes for you.
good luck!
Postby Underdog » 23 Mar 2010 21:06
Yep, and that goes for the new stuff too. Had to change out the resistor for the heater blower on the GF's Grand Prix. Way up under the dash on the passenger side near the firewall. Only two bolts fasten the seat on it and you can hit them with an air gun.[:)] As I grow older, I find it necessary to find the easiest and less painfull ways to do things. The pain doesn't go away as quickly as it used to.[:(]
Jim Underwood
Users browsing this forum: No registered users and 106 guests
