Differential Oil Seal
Postby REPLIC8 » 16 Feb 2010 17:59
How easy is it change the front oil seal on a 5 speed diff? I think it just pops out & then push a new one in but the factory workshop manual says you need a special tool to remove it & another one to put it back in. Is this right or can it be done with normal tools?
Postby busheytrader » 16 Feb 2010 19:30
If it's the pinion oil seal UKC4995 then nothing special is required to remove and refit the seal. I did mine as per the Haynes manual.
My recon supplied 3.08 axle had a smear of silicon instead of a gasket fitted
Postby Underdog » 17 Feb 2010 22:23
Some silicone (RTV) on mine also as I didn't have the gasket at hand. No leaks. One of the nice features of these rear axles is being able to change that seal without disturbing the pinion preload.
BTW, I did mine with a block of wood, hammer and flat surface.
Jim Underwood
Postby REPLIC8 » 18 Feb 2010 06:24
Thanks lads, I'll order the bits & have a go. [:)]
Users browsing this forum: No registered users and 93 guests
