Floor pan holes
macmattom
Floor pan holes
Postby macmattom » 30 Dec 2009 18:43
<font face="Comic Sans MS"><font size="2"><font color="blue">I have the carpet out of my car at the minute (well - three years nearly!) and was wondering if the holes in the floor plan are meant to be left unobstructed to act as a water outlet or if they should be blocked with a gromet.
I have added a couple of pictures to show the driver's side, but there are also some on the passenger side.
Thanks,
Mac.
</font id="blue"></font id="size2"></font id="Comic Sans MS">
Postby busheytrader » 30 Dec 2009 21:59
One of them looks like the holes for the seat frame mountings but it's been a while since I looked under my carpet.
I'd fit the grommets unless you have refitted the moulded carpet. (unlikely) I drove without the floor grommets in heavy rain and water came up through the floor. Damp carpet doesn't smell too nice. Then again my 7 still smells of waxoyl. If you're worried about moisture with grommets fitted you can always lift up the carpet section to check periodically.
I never bothered with the grommets in spare wheel well. There's nothing for moisture to soak into and it flows out again.
nadg63
Postby nadg63 » 30 Dec 2009 22:08
Having stripped out two shells this year, those holes were in the floor of both of them - don't have a use so no idea why they are there!? (being a BL car probably water outlet)
Postby FI Spyder » 31 Dec 2009 18:39
Not sure where the bottom one is but the top picture, the hole is under soundproofing so would effectively be covered by it. The only other holes are the four bolt hole for the inside of the seat mounts so would be filled with seat mounting bolts (these may be what you are showing in the bottom picture.
Postby Beans » 01 Jan 2010 11:17
If the holes are visible from beneath fit a grommet, if they are above a box section leave them open.
There are 4 holes in the floor you should plug with a grommet.
All are near the large big holes (two in the footwells two near rear bulkhead)
And a picture of the holes in the front area of the floor. Two small holes that need a grommet here are just visible to the inside of whre in my case th elarge holes used to be ...
<b>http://tr7beans.blogspot.com/</b></i></center>
macmattom
Postby macmattom » 01 Jan 2010 17:19
<font face="Comic Sans MS"><font size="2"><font color="blue">Thank you very much - sorted. Happy New Year, and here's to hoping my car will be on the road before this time NEXT year!
Mac.</font id="blue"></font id="size2"></font id="Comic Sans MS">
