DHC: How much space above gas tank?
moss0031
Postby moss0031 » 13 Dec 2009 18:51
Hello all,
Long time lurker, first time poster. I was planning on installing some speakers in my rear deck of my 79 DHC (yes, they will be muffled by the tonneau when the top is down). How much clearance is there between the gas tank and this panel? I've tried to check the parts diagrams, but I couldn't find one that showed this very well. Just though i would ask before I start drilling. :)
Thanks!
_Rob
Postby stevie_a » 13 Dec 2009 18:59
<font color="maroon"><b>In the summer I am getting custom fit speakers just under
the hood protector pods just at your shoulder
this means I can hear them with the roof up or down
A professional company is doing it
This might be somthing you might thing of </b> </font id="maroon">
Red
Postby Red » 13 Dec 2009 19:01
Er, about 1/8 inch. The tank fits right up against the panel, with only a couple of rubber strips keeping it away from the metal.
Aren't you glad now that you asked first? [:D]
Garry
1976 2.0 (soon to be 3.5!)FHC
http://reds-tr7.blogspot.com/
Postby PeterTR7V8 » 13 Dec 2009 19:16
Mine are on the top of the shelf where there should be plenty of room.
richards
Postby richards » 13 Dec 2009 19:40
6x9's will fit in the front doors but you have to heavily modify the door cards. i can here mine clearly with the top down at 70mph. ( I made my own door cards rather than cut the originals)
Get a lifestyle
Get a TR7!
www.ttr7.co.uk
moss0031
Postby moss0031 » 13 Dec 2009 20:03
I should note that it is a pair of 6x9s that I'm looking to fit with a mounting depth of about 4 inches. Right now I'm considering some sort of wedge-shaped (naturally!) enclosure to fit above the panel. Probably something I'd have to build myself as I don't trust the amount of rear vision I'd have with these:
http://www.crutchfield.com/p_2366900/Ba ... -6900.html
@stevie: That's not a bad idea, looks like there might be enough space to fit a decent sized speaker there. Only thing it could foul would be the seat when moved fully rearward (though in my case I have Miata/MX-5 seats so they are a bit thinner than the stock seats). Other place i was just looking at is the back panel immediately behind the rear deck (so they would mount vertically). However, I'm guessing that they wouldn't be able to protrude much from there without fouling the top/hood when lowered.
@peter: DHCs aren't lucky enough to have the parcel shelf. :)
@Red: Thanks! That's what i feared ... does the tank run the full width of the panel? Any chance I could squeeze them in on either side?
Postby Beans » 13 Dec 2009 20:21
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by moss0031</i>
... Any chance I could squeeze them in on either side? ...<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
No room there, tank and mounting point for the seat belts being in the way ...
moss0031
Postby moss0031 » 13 Dec 2009 20:55
Thanks Beans, that is the exact picture I was looking for. I appreciate it.
Maybe I should just fit a fuel cell in the trunk! :)
InfilTR8
Postby InfilTR8 » 14 Dec 2009 03:53
I thank you also, Beans. I needed to see that too. Does everything below it have to be removed to get the tank in and out? I was about to check the Haynes book. [:)]
Ima TRyFixTR8 my first Triumph
Postby Cobber » 14 Dec 2009 04:29
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by InfilTR8</i>
<font size="2"><font face="Comic Sans MS">Don't waste your eyes on the Haynes book, save them for porn. [:D]
There have been plenty of threads on this forum in regard to removing/replacing the fuel tank that will provide useful tips on how to do the job unlike the Haynes book which is largely a waste of ink and paper.</font id="Comic Sans MS"></font id="size2">
85'Alfa 90, 69'Ford F250.
Postby jclay (RIP 2018) » 14 Dec 2009 12:58
You could always do what Orange Rag did to his car.
"They are from a late 90s Saturn s series 4dr. It is screwed on to the door panel from the back so I attach them the same way. You may need to put longer fastening clips on the bottom of your door panel so they secure to the door.(because of the heads of the screws or use flat head screws)
There is lots room for speakers so I upgraded mine. I think I paid $20.00(Canadian) for two door panels, than I had some spray vinyl dye and presdo! a cheap fix and my kind of budget."
I attached small speakers from Radio Shack under the top strut covers. That gave me sound from the back as well.
Postby Underdog » 14 Dec 2009 13:25
Funny but since I got the new engine in, I don't seem to turn the stereo on much.[}:)]
Oh and welcome aboard. You will find this a very useful site for sure.
Jim Underwood
Dan B
Postby Dan B » 14 Dec 2009 15:56
I have added a box with 8 Walmart speakers in series/parallel, across the shelf between the seat belt reels. The box is just big enough to hold the 4" speakers and provide enough space behind the speakers for them to operate properly.
I started out making a wedge shaped box. tapering down under the hoodsticks all the way to the back of the shelf. When I put the hood down, I found the hood would not go all the way down. The box needed trimming, so I marked it and cut it off, then sealed the back with another piece of plywood. I used some scrap 3/8" plywood I had lying around to build the box. I also used plywood to make interior partitions (baffles) separating the speakers, but put holes in them to allow air movement inside. The speakers were installed on the face of the box, then wired together in series/parallel to equal the 8 ohms needed for each side.
The speaker box makes good sound, is right behind your head where it doesn't need to be so loud, and clears the hood cover when it is installed. On mine, the inside snaps won't quite snap (the ones behind the seats) but I never snap those anyway. This method of using the smaller speakers apparently is used by Dolby, according to my brother Jim.
Dan B
moss0031
Postby moss0031 » 14 Dec 2009 17:45
@Dan B: Sounds interesting and is the direction I am currently thinking. Happen to have any pics handy?
I've already enlarged the door panels to fit 6.5" speakers and installed tweeters in the dash. For the rear, I'm now considering making an enclosure out of fiberglass to fit both 6x9 speakers (angled back at 45 degrees or so, however they lay the flattest) behind the seats. If i put that in place instead of the existing trim panels (and with removing the rubber mat underneath) hopefully it won't obscure the rear view too much and still allow the top/hood to be fully stowed. Granted, there will be issues with the tonneau, but I'm not as concerned with that.
Dan B
Postby Dan B » 15 Dec 2009 01:46
Unfortunately, I left my camera at the office. If I remember to get it tomorrow I will take some pictures.
This design allows for full top stowage and the top cover or whatever you call it fits over it to where you cannot even tell the speakers are then when the top is down. If I take pictures you won't be able to see that because I have the hardtop on it now that the weather is cold. The top frame/hood sticks fits behind the speaker box.
[url][/url] http://www.mobileinformationlabs.com/Ho ... wiring.htm
