Rear drums
Rear drums
Postby stevie_a » 05 Dec 2009 20:09
<font color="maroon"><b>After replacing the front discs with EBC
and it making a big difference
I was wondering can you get such a thing as up graded drums
i.e grooved and drilled or similar</b></font id="maroon">
Reddragon
Postby Reddragon » 05 Dec 2009 21:15
Why would you want drilled or groved drums?
In my opinion that would let to much road debris in. If you want, if I am not mistaken, the Alumninum drums that fit a Tr6 or 240Z are the same size. You would just have to hsve the wheel stud holes and center hole resized for the Tr7.
I understood that you wanted to up grade to something different, just did not understand your statement of drill and groove. As Bean stated this is what I had in mind for a bling look if you wanted something different.
http://www.zeni.net/trf/webcatalog/specials6.23/38.php
Dale
1974 TR6
1977 TR7 FHC
Postby gaz » 05 Dec 2009 21:18
or.......
go the whole hog, S&S do rear disk conversion
http://www.ss-preparations.co.uk/images ... 4%20(Small).JPG
Postby gaz » 05 Dec 2009 21:22
ok link didn't work but they can be found on there website
Postby stevie_a » 05 Dec 2009 21:36
<font color="maroon"><b>No I don't want to groove or dill my drums
Just wondered if there was an option to up grade the drums
You can do the the front why not the back
do you see what i mean</b></font id="maroon">
Postby Beans » 05 Dec 2009 22:30
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by stevie_a</i>
... You can do the the front why not the back ... do you see what i mean <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
You could try to find some alloy finned drums if you really want to. But an upgrade of the (rear) drums is quite unnecessary as long as you don’t do anything to the front/rear brake bias. You might buy some brakes shoes with better friction material.
And if you are going to change the brake bias, it is better to change to discs i.m.h.o.
Postby PeterTR7V8 » 06 Dec 2009 05:54
You can get bigger slave cylinders for the rear drums. They will apply more pressure on the shoes but before you do that you might want to substitute the factory proportioning valve with an adjustable valve which will have the same effect up to a point.
Postby Hasbeen » 06 Dec 2009 09:16
I fitted rear discs as part of upgrading the rear end to a stronger
diff, with a propper SLD.
It made absolutely no difference to the braking, in hard public road
driving.
See my photos for a pic of them.
Postby stevie_a » 06 Dec 2009 09:17
<font color="maroon"><b>jclay mats were in the car when I got it [;)]
Peter I already have the 4 speed cylinders on the back
This was just somthing that crossed my mind I think going to rear
discs is a bit to extreme for me..</b></font id="maroon">
Postby stevie_a » 06 Dec 2009 17:52
<font color="maroon"><b>jclay sorry I don't get what you mean
I wasn't talking bling
Or am i missing somthing?</b></font id="maroon">
Postby stevie_a » 06 Dec 2009 18:14
<font color="maroon"><b>I did see what had happened...Image
Deleted post and that...Image</b></font id="maroon">
Image....Image
Postby FI Spyder » 06 Dec 2009 18:35
Most braking is done by front brakes so as Hasbeen says upgrading rear brakes would make little difference especially considering the high cost of conversion to discs. Unless your racing it where cost is secondary (or tertiary). In my case the rears lock up slightly before the fronts so I would want less rather than more braking there. (Stock tire sizes and mechanicals).
