LIGHTS
GARY KNIGHT
LIGHTS
Postby GARY KNIGHT » 18 Nov 2009 17:22
Need to check the lights out not lifting.Does anyone know what the hell the delay unit is for and where it is mine is a 1981 2.0l
Postby TR Tony » 18 Nov 2009 17:47
Gary, if the lights come on when you operate the switch, but neither pod raises, then check out the switch in the dash first.
The delay unit is used to hold the pods up for a few seconds when you use the headlamp flash - also known as the Pecktron unit. It is in the fuse box at the back of the glovebox. Check the main switch in the dash first, take it out & check for damage or dirty connections.
TR8 FHC EFI Factory development car Inca Yellow</font id="size1">
Postby stevie_a » 18 Nov 2009 17:53
<font color="maroon"><b>if you use the search option you will find Lot's on the subject
But basically clean the connections in the engine bay just before it goes on to the pods
also the clean the connections at the switch
and finally the delay unit is called the pecktron unit and when you flash your lights
the pecktron keeps the pods up for about 7 or 8 seconds ( lights will only light up as long as you hold the stock back)
and it is located just by the fuse box at the back of the glove box</b></font id="maroon">
Postby stevie_a » 18 Nov 2009 17:58
<font color="maroon"><b>would you look at that two answers at the same time ...[:D]</b></font id="maroon">
Postby bmcecosse » 18 Nov 2009 22:55
If the lights come ON - but don't rise - it's not the lighting switch! Start checking the wiring. If the lights don't come on - then indeed - check the switch - it is notoriously prone to failure, but supposedly responds well to stripping and cleaning.
I find the 'delay' etc is so pathetic - that it's just not worth 'flashing' with the stalk - by the time the lights rise, and you have to keep your hand on the stalk anyway to keep the lights lit - the need for the 'flash' is about 100 yds behind you! If you just briefly tug the stalk as on any other car - the lights tediously rise and fall - but are not lit - so it's more of a 'blink' than a flash!
Postby john » 19 Nov 2009 06:34
Sorry bm have to disagree there if the lights come on and they don't rise it could very well be the switch as this was the cause on both my cars....
try wigglimg the switch about first then clean all the connection throughout and it's always best to have a spare switch that'll cost you £14 approx
one other tell tell sign was the turn the sidelights on then try the flash feature again this pointed for me anyway to the switch
give that a go
Postby UKPhilTR7 » 19 Nov 2009 11:09
Last time I have an issue with my lights it ended up being the breaker unit that had gone. My lights would come on, but no lift. I changed the main light switch, cleaned all connections and checked all fuses/relays, before checking the breaker.
I was told to take out the little breaker unit that can be found in the fuse box and just connect the points with a cable. did this and the lights went up. That was my issue. May not be yours, but worth a go before you start buying new switched/fuses, that may not be needed in the end.
Postby Cobber » 19 Nov 2009 11:15
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by UKPhilTR7</i>
No matter, YOU WILL need them sooner or later! [:D]
85'Alfa 90, 69'Ford F250.
