Fresh Air Scoop Seals
Postby REPLIC8 » 31 Oct 2009 19:50
http://cgi.ebay.co.uk/Triumph-TR7-TR8-Fresh-Air-Plenum-Seals-Reproduction_W0QQitemZ230393687554QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item35a488ae02
Spotted these on Ebay. Has anybody tried them to see if they fit OK? Mine are still in place, but could do with a spare set just in case. As far as I know OE parts are unavailable, these are the first reproduction ones i've seen.
Postby jclay (RIP 2018) » 31 Oct 2009 20:54
I have them on my TR7. Difficult to figure out the fit as I had never had any before. Work well once installed.
humanoid
Postby humanoid » 31 Oct 2009 21:54
I bought those things awhile back, not even sure where they go! [:0]
_____________________________________________
<h3><b><font color="orange">1980 Inca Yellow TR7 Convertible</font id="orange"></b></h3>
Postby FI Spyder » 01 Nov 2009 00:13
Made my own using originals as templates. Even if you don't have originals, not rocket science.
Marko
Postby Marko » 01 Nov 2009 00:36
any installed pics?
Postby TR Tony » 01 Nov 2009 07:50
These have been reproduced by a guy called Wayne Simpson who subscribes to the TR8 list. I have bought a couple of sets, they work well.
Originals were glued to the air scoop & press up against the bulkhead when you clip the scoop in place. I haven't glued mine, just pressed them into place - bit fiddly but once in place they stay put. You get instructions from Wayne in case you have no idea where they fit!
As FI Spyder says, simple to make if you have a template, just two cut outs of suitable foam glued together.
TR8 FHC EFI Factory development car</font id="size1">
Postby tr7inc » 01 Nov 2009 08:24
While im working on the engine bay and the air scoop is off etc, think i might just try and make my own also, im sure i have a smilar foam in my garage somewhere, and when i looked at mine when i took the scoop off, it 30 years had takent there toll and had all but completely perished, so i'll have a go and see what happens.
Postby busheytrader » 01 Nov 2009 08:30
I bought my DHC when it was 6 years old and I don't remember seeing these.
When Grinnal restored the bodywork all the removed misc parts were replaced from a pool of other 7's bits. I got someone else's rough air scoop and I never saw these seals either.
TR7 V8 DHC Jaguar Solent Blue. 9.35cr Range Rover V8, Holley 390cfm, JWR Dual Port, 214 Cam, Lumention, Tubular Manifolds, S/S Single Pipe Exh, 3.08 Rear, 200lb Spax & PolyBushes all round, Anti- Dive, Top Roller Bearings, Capri Vented Discs & Calipers, Braided Hoses, 4 Speed Rear Cylinders, Uprated Master Cylinder & Servo, AT 5 Spokes and Cruise Lights. S/S Heater Pipes. No Door Stickers. Mine since July 1986, V8 from 1991
