How long should the dipstick tube be?
MrT
Postby MrT » 15 Aug 2009 19:00
Just wondering, 'coz I don't think mine's long enough, as there's definitely not too much oil in it , but it's waaaay over the maximum mark. Surely there must be a better solution than a stupid rubber hose..?
Austin A60 pickup
Triumph TR7
Yamaha SRX-6 (x2)
Suzuki GS500E
Ford Maverick
Fiat Idea
Jolyon39
Postby Jolyon39 » 15 Aug 2009 22:37
Hi MrT,
The best way to sort this is to install a new rubber pipe that is too long, drain the oil and refill with the exact amount as per the manual. Next you just trim down the new rubber pipe until you get an exact Full reading on your dip stick.
My ROM says that the engine sump and filter capacity is 4.5 litres and the sump only is 4.0 Litres. I am told that you should replace the filter when doing this, run the engine to fill the filter and then do your measurements from there.
regards,
Jolyon
Postby Beans » 15 Aug 2009 22:41
Or do a search on this forum as this topic has been covered quite extensively in the past [:)]
Postby Underdog » 16 Aug 2009 15:52
Any of you guys get the TV oil commercial with the little Scot running around wacking guys in the behind with a dipstick? That's thinkin with yer dipstick Jimmy!
Sorry, Sunday morning & feeling a bit silly. Title of the post brought the comercial to mind. Hard to imagine if you haven't seen it.
Jim Underwood
Spectatohead
Postby Spectatohead » 18 Aug 2009 07:18
As Red Green, er, Underdog said, it is a stupid little commercial for Castrol's new synthetic, and now you've stuck it in my head and it won't go away.[:D]
http://www.youtube.com/watch?v=Mj5ms9PJDNY
Jim Clark
'80 TR8
'97 Maxima 5spd
