QUARTER GLASS REMOVAL QUERY
Postby tr7inc » 13 Jul 2009 11:04
hi guys, just wondered how easy it was to remove the quarter glass windows as mine ar fiarly scrathed and am looking at getting a pair when i see some, i presume once door cards are removed, that they are bolted to the inside door frame?
Thanks for any help as always
Rblackadar
Postby Rblackadar » 13 Jul 2009 12:13
I think there is a screw at the top of the the door you need to loosen in order to get at it.
Postby Beans » 13 Jul 2009 16:42
You are quite right there Steve [;)]
In a nut shell ...
To start with you indeed have to remove the complete quarter-light-frame.
For that you need to remove the door trim and the side window, thus giving access to the mounting bolts (2 per side) and nuts (1 per side) if I remember correctly.
After that pull out the frame, drill out two pop rivets holding the base plate in place and remove quarter light with its seal ...
Postby jclay (RIP 2018) » 13 Jul 2009 16:49
<font color="purple"><i>Opps! Sorry, Beans, I guess we were both answering at the same time!!</i></font id="purple">
There are three bolts and one nut that hold the frame in place.
Remove door card, remove the window winder, remove the window.
Remove the window stop. Remove the nut up high on the inside hinge side of the door, remove the bolt on the outside of the door just above the hinge. Remove the two bolts holding the frame to the inside of the door around the window winder area. Slide the window frame up and tilt to the back to clear the front edge of the frame from the door.
Rotate the frame so that the upper bracket on the back post can clear the opening for the side grass. Remove the frame.
Postby tr7inc » 13 Jul 2009 18:11
Nice one fellas, i'll give it a try and let you know how it goes
Postby Beans » 13 Jul 2009 19:30
<font color="purple"><i>Opps! Sorry, Beans, I guess we were both answering at the same time!!</i></font id="purple">...<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
No need to apologize, and your post is slightly more complete [;)]
Postby jclay (RIP 2018) » 13 Jul 2009 22:08
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">and your post is slightly more complete<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
Only because I took two doors completely apart last week!
Users browsing this forum: No registered users and 81 guests
