What's the best way to bring down revs at cruise speed?
Re: What's the best way to bring down revs at cruise speed?
Postby Hasbeen » 20 Jun 2016 15:13
After running in I put the thing on a wheel dyno, [rolling road], & set the distributor at the highest power output, full throttle at 3000 RPM.
This gives me the best ignition timing at normal cruising speeds on our country roads around home.
I keep a regular check on fuel consumption. I fill the tank to the top each filling, & watch the usage. This tells me if problems are starting. An increase warned me a rear brake was starting to drag. A sudden increase from just under 9L/100Km to 14 L/100Km with no obvious reason sent me looking seriously.
I found the solder on the fuel sender/pickup fitting had cracked. The welds held it in place, but it was leaking. Not enough to drip or even smell noticeably. It was stained around it, but the fuel evaporated off as it wept out. When a full tank lost 2 litres in a week, sitting in the shed, I confirmed it as the problem.
edgyWedgy
Postby edgyWedgy » 20 Jun 2016 19:14
I'm curious what timing you did achieve? I plan on testing with the dyno bench, but it'll take some time till i get the chance.
I plan on keeping record of my fuel consumption also, and that can be really beneficial for finding problems early i understand from your post. :) I'm doing good so far, going 300km on half a tank in the past two weeks. And that's with enthusiastic driving on a regular basis.
My brakes are doing good also, except for the part that i once forgot to release the handbrake for a kilometer or 5... :oops:
Brakes were barely hot though, since the handbrake doesn't do much in my case.
Why did you set the ignition while doing 3000rpm if i may ask? Did you get the most torque at that rpm?
'76 FHC TR7
