Wedgie, how aero?
Postby PeterTR7V8 » 17 Nov 2009 23:24
That's an interesting idea. They look pretty easy to make.
http://www.fuelsavers.com.au/
Marko
Postby Marko » 18 Nov 2009 14:21
emm,
you will reduce lift by inducing drag?
the only thing that can help tr's aerodynamics is to remove that 90 degrees bend that the rear glass forms, air cant go around a 90 degrees bend easily , no matter what aerodynamic element you use.
only solution would be streamlining it down o the rear end of the trunk lid . and god knows how ugly would that look like.
it would require less than 7 degrees taper from the tangent line for air to follow it, like a reverse under-tray diffuser
Postby PeterTR7V8 » 18 Nov 2009 19:10
Actual drag data for our cars & a lot more besides.
http://www.mayfco.com/tbls.htm
http://www.mayfco.com/triumph.htm
