TR7 / Dolomite Sprint Conversion - SU CARBS
moodyblue
Postby moodyblue » 15 Mar 2014 19:00
Before I get rid of the sprint carbs, is bonnet clash with the TR7 (High)dashpots a possibility?
Postby dursleyman » 15 Mar 2014 20:50
[quote]<i>Originally posted by moodyblue</i>
It might well be but I had the Sprint screw-on oil filler cap touching the bonnet(hood). Solved that one by using the TR8 subframe spacers.
You might also get the exhaust touching the chassis rail. Two fixes for that problem are to bend/hammer the exhaust, or a small machining of the right side engine mount to make the engine lean over a little to the right. I can post some pictures if you want.
1980 TR7 Sprint DHC
g4zur
Postby g4zur » 15 Mar 2014 21:02
Hi Hasbeen
Today took the HS6 su's off the dolomite manifold. so have the linkages you mentioned going free of charge if you want them. would be my pleasure to send them to you.
Regards Gareth.
G.P.Albrighton
Postby Hasbeen » 15 Mar 2014 21:26
Thanks Gareth, but I wasn't looking for anything mate, just comparing the prices for 7 stuff, over here in the colonies.
moodyblue
Postby moodyblue » 15 Mar 2014 22:59
Thanks for the info. I did a search before and noted the modifications that might be required to the exhaust and/or mounting. I hope that I get lucky and avoid all that. I'd better keep the low dashpots just incase.
g4zur
Postby g4zur » 16 Mar 2014 06:24
Am I right in thinking that the low dashpots can be used on the wedge?
Regards Gareth
G.P.Albrighton
moodyblue
Postby moodyblue » 16 Mar 2014 08:52
I think they can be used because the carb bodies are the same.
g4zur
Postby g4zur » 16 Mar 2014 11:16
Hope your right. spent two days polishing them.
Regards Gareth
G.P.Albrighton
Postby dursleyman » 16 Mar 2014 14:33
[quote]<i>Originally posted by g4zur</i>
Regards Gareth
G.P.Albrighton
The low dashpots certainly work well on mine.
1980 TR7 Sprint DHC
g4zur
Postby g4zur » 16 Mar 2014 16:00
Thanks Russ.
G.P.Albrighton
whitenviro
Postby whitenviro » 19 Mar 2014 15:02
Russ: I'd be interested in seeing the engine mount modification you did to get the engine over the the right. Doesn't that make the oil fill sit even higher?
[/img]
tr7sprint1
Postby tr7sprint1 » 19 Mar 2014 15:44
Its on his blog (pictures provided).
jeffremj
Postby jeffremj » 19 Mar 2014 17:32
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by whitenviro</i>
I'd be interested in seeing the engine mount modification you did to get the engine over the the right.<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">The lots of info and pictures are to be found in this forum. This page shows the problem and my cure:
http://forum.triumphtr7.com/topic.asp?TOPIC_ID=11956&whichpage=8
This one shows the end product after following my advice:
http://forum.triumphtr7.com/topic.asp?TOPIC_ID=11956&whichpage=12
The whole thread (11956) from 2010 is very useful for 16V-ers.
