OMG
Postby Beans » 18 Jun 2009 18:08
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by nofinchance</i>
....What should I do with these[:I] clean answers only please...<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
OK if that pleases you, here goes for the clean answer [:p]
<ul><li> 1. Two parts bottom left fit to the "A" post. Piece to the left fits lefthand footwell</li>
<li> 2. Vinyl trim pieces bottom cntre fit to the "B" post were the hood frame is mounted (see piccies below)</li>
<li> 3. The carpet pieces bottom right fit over the inner rear arches, with the edge facing outward (also see piccies below)</li>
<li> 4. Large piece of carpet top right (should have a base board underneath) lies on rear shelf with holes (for seat belt mount) facing to the front</li>
<li> 5. Two pieces bottom left fit to the outside of the vertical rear panel, covering most of the trim pieces mentioned under 2. Curved edge faces down </li>
<li> 6. I am missing the trim piece for the central vertical section in your picture.</li></ul>
nofinchance
Postby nofinchance » 18 Jun 2009 18:32
Once again I am in awe of your mass of knowledge guys.[:0].I now see what goes where ah hem[:I].I am going to get spraying with the waxoil and painting with rust proffer while I have the car naked.Then it's out with the glue.The car is a DHC so do I have some extra bits then?
[:(] I am missing a piece though.If you would hang onto it please Mr birminham TR7 I will pop along at a mutually conveniant time to fetch it.Thankyou again for your help and knowledge you were correct the ignition light control was the offender on my oil light.It was great to meet you good luck with your project it's lovley.ME FIRST ME FIRST if you want a tester when it's done[:D]
birminghamtr7
Postby birminghamtr7 » 19 Jun 2009 18:43
Beige seats !!!!!!
http://cgi.ebay.co.uk/Triumph-tr7-sprin ... 7C294%3A50
Users browsing this forum: No registered users and 92 guests
